My car is driving me crazy!!! - Mustang Evolution
Old 09-12-2012, 08:31 AM   #1
I have a 1994 Mustang V6 and it drives me crazy around every corner with these little irritating things that I tried to do DIY stuff on, but cannot figure out. I do not want to have to shell out money for a professional to handle, but I just might....
  1. Tail lights do not work, but brake lights work.
  2. Front and rear turn signal do not work. Turn signal relay and turn signal switch have been replaced
  3. Gauge cluster needles work sometimes and sometimes they do not. They don't work more than they do.
  4. Gauge cluster lights do not come on when the headlights are on, but they come on if I push the headlight knob in a click, but at the point the headlights are no longer on.
This is all so crazy... Any ideas from the Mustang Gurus?!?!
devanslive is offline   Reply With Quote
Old 09-12-2012, 08:47 AM   #2
V6 stang's Avatar
Is a fuse out? Lol I have no idea XD
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 09-12-2012, 08:52 AM   #3
Re: My car is driving me crazy!!!
I checked all of the fuses and they seem to be in order and not blown. I can only assume that it may be something electrical or a short lurking somewhere.
Old 09-12-2012, 09:07 AM   #4
deadsp0t's Avatar
Headlight switch. All day everyday
Be prepared as you may have to repair or replace the plug and or harness where it plugs in to the switch
That's unimpressive
Old 09-12-2012, 09:20 AM   #5
Headlight Switch?!?! That is what someone else said. So, the switch itself is a pretty straight forward replacement. However, to change the harness that is a little more involved. If I change the harness would I need to cut out the old one and splice it into the new one?
Old 09-12-2012, 09:28 AM   #6
deadsp0t's Avatar
Yup, I've been through this on several cars. Same symptoms and all. Very straight forward.
With the switch pulled out, there's an opening in the stem, push something in to press the tab and slide it off the switch itself.
2 screws hold the trim over the gauges, remove and pull trim off carefully. There are two screws holding it in place. Once removed you will see the extent of the damage.
If itts real bad i hear American Muscle has some sort of repair kit or you can source at a junk yard.
That's unimpressive
Old 09-12-2012, 09:31 AM   #7
A repair kit for the headlight switch?
Old 09-12-2012, 09:33 AM   #8
deadsp0t's Avatar
Harness and plug I believe, not positive just what I remember reading
That's unimpressive
Old 09-12-2012, 11:06 AM   #9
91notchback's Avatar
Yes it does come with harness and plug. Ill try to post a link for you soon. Save yourself some headache and do it right with shrink wrap and the whole nine yards.
---------- Post added at 12:06 PM ---------- Previous post was at 12:00 PM ----------
//www.latemodelrestoration.com/item/WPT165/94-04-Mustang-Headlight-Switch-Connector
91notchback is offline   Reply With Quote
Old 09-12-2012, 01:19 PM   #10
And here is the AM link:
http://www.americanmuscle.com/headli...ness-9404.html
Old 09-12-2012, 08:38 PM   #11
deadsp0t's Avatar
Originally Posted by 91notchback
That's unimpressive
Old 09-12-2012, 09:22 PM   #12
Thanks a bunch!!!
Old 09-13-2012, 04:53 AM   #13
deadsp0t's Avatar
Thanks a bunch!!!
Np at all! I take it you got it sorted out then?
That's unimpressive
Old 09-13-2012, 07:20 AM   #14
Okay, so I need to get my hands on the harness and then purchase the switch as well. Cool... Thanks!!!
Old 09-13-2012, 07:24 AM   #15
You bet man. As I say, you will save yourself some future headache by doing it right the first time. Soldering, shrink wrap, etc. Best of luck to you! :good
Old 09-13-2012, 09:13 AM   #16
Please update. Very informative, well written thread. I would also suggest inspecting and cleaning thoroughly the negative & positive- both battery terminals, exposed copper cables & connections. Good luck.
Old 09-13-2012, 09:23 AM   #17
So, using regluar clamps for splicing the wires will not be good enough? I will pick up some shrink wrap from AutoZone then when I pick up the Headlight Switch and Harness... I will be doing this myself so I am a little nervous about that, but I will just follow directions and take my time. Thanks a million!!!
---------- Post added at 11:23 AM ---------- Previous post was at 11:22 AM ----------
I will clean the battery terminals too.
Old 09-13-2012, 09:26 AM   #18
deadsp0t's Avatar
It will be good enough if you heat shrink it, he is just giving the best, most effective and longest lasting way. Just take your time and you will be fine! i can almost say with out a doubt this will cure your issue. If you can take pics.
That's unimpressive
Old 09-13-2012, 09:29 AM   #19
I will definitely post pics of it all. I need to post pics of the entire clean up from what the car looks like now and all of the repairs done... lol
Old 09-14-2012, 10:48 AM   #20
BrandonL's Avatar
If the harness or the switch doesn't work make sure you check the bulbs. I had some issues exactly like this on my 1997, I had to replace a couple light bulbs and sand some terminals in the bulb socket because they were a little rusty/corroded. I also bent the terminal connectors inside of the bulb sockets out a little more so that they would make better contact with the lights.. Hope this helps... Good luck!
BrandonL is offline   Reply With Quote
Old 09-14-2012, 11:07 AM   #21
Hmmmm... Interesting, never thought of the sanding and bending.
03:42 AM
