How can i get more torq for my 2001 v6 - Mustang Evolution
Old 09-13-2012, 07:25 AM   #1
V6stang6272's Avatar
Since I've installed my xpipe I've lost a lot of lower Rpm's but a lot more top end performance.
I'm sticking with a v6 and wanna prove the gt's I can smoke them.
I only have:
X-pipe not catted
Dual 10 series
All new ntk o2 sensors
K&n intake
HELP ME
V6stang6272 is offline   Reply With Quote
Old 09-13-2012, 07:30 AM   #2
Horseplay's Avatar
buy some longtube headers and have your muffler shop fab your x pipe so you wont have to buy another shorty x. buy some gears and buy a tuner. bam !
Low2v
Old 09-13-2012, 07:36 AM   #3
What do you mean fab my xpipe
? Meaning cut? I have my xpipe so I can unbolt and put my cats back on so I can get it inspected.
Old 09-13-2012, 07:54 AM   #4
Horseplay's Avatar
well with longtubes it wont fit if you have a normal sized mid pipe. im sure it wont affect it if they cut ur xpipe a bit to make the longtubes fit.
Low2v
Old 09-13-2012, 08:57 AM   #5
Re: How can i get more torq for my 2001 v6
The day after I installed my dual exhaust, I ordered a VAP lower intake spacer. Gained the low end torque back.
Old 09-13-2012, 06:23 PM   #6
lemons95's Avatar
A 4.2 stroker would probably be best.
you can re-use a lot of your parts.
I don't know about the new split port engines but for my single port v6. I needed a new harmonic balancer and flexplate.
Old 09-14-2012, 11:49 AM   #7
This may have nothing to do with your situation mentioned but it reminded me of the fact underdrive pulleys for your particular generation provides harmonic balancer with the drive pulley, with the second alternator pulley.
Old 09-14-2012, 07:04 PM   #8
davidcseifert's Avatar
Region: Arkansas
you lost your low end when you took the cats out.. the medium ground is a nice set of high flows that let you keep some of the low end yet breath more up top
blower/new cam soon
Old 09-14-2012, 10:12 PM   #9
Dgerow12's Avatar
+1. They worked wonders on my 00 sixxer. I ran o/r gt exhaust fabbed from manifolds back and I added high flows and they helped alot
Dgerow12 is offline   Reply With Quote
Old 09-15-2012, 05:42 AM   #10
Kingmidas87's Avatar
Also to help make it "quick" invest in an aluminum flywheel. I swear to you man, it like taking 300lb outta your car! It revs quicker and it's way noticeable.
Kingmidas87 is offline   Reply With Quote
Old 09-15-2012, 06:44 AM   #11
I used two glass packs in front of my flow 40's gave me back some low end and changed the note a ton and only cost 150.00 compared to what ever high flow cats cost. I dnt know how 10's will sound with this though.
l2plagears is offline   Reply With Quote
Old 09-15-2012, 10:07 AM   #12
Dgerow12's Avatar
High flows are only 200 bucks from AM
Old 09-15-2012, 11:12 AM   #13
DaBluedude's Avatar
Need more torque... Drop in a v8
2003 Mach 1
Old 09-15-2012, 11:27 AM   #14
Stockish302's Avatar
Tbird blower!!!!
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 09-15-2012, 11:44 AM   #15
1slosix's Avatar
what kinda glasspacks? just curious because i've never seen them more then $25 a pop
carving corners like a boss
Old 09-16-2012, 04:01 PM   #16
Region: Arkansas
not sure how glasspacks give you anything on the low end seeing as they're straight through design offers no resistance...
blower/new cam soon
Old 09-16-2012, 05:11 PM   #17
Dgerow12's Avatar
Idk about low end but I can see how it could change the tone for the better. I just don't like how they sound after they break down. When I first got my o/r bassani x and glass packs on my old six it sounded BA. But after they started to break down they buzzed at about 3000 rpm
Old 09-16-2012, 05:26 PM   #18
Originally Posted by Stockish302 View Post
Tbird blower!!!!
The SuperCoupe M90 would not help out much since he's got a split port 99+ 3.8. He'd have to convert to a single port and lose 40hp
The 94-98 single ports respond well to those m90's, but you need a M112 or other type of FI on the split port for the gains to be there.
Old 09-16-2012, 06:36 PM   #19
PlastiDip your air filter
Old 09-16-2012, 06:54 PM   #20
Dgerow12's Avatar
I know people are just messing around when they say this but we should really think about what were saying because some people will actually do these things just because we said too. We're supposed to help other less experiences than we are.
---------- Post added at 08:54 PM ---------- Previous post was at 08:46 PM ----------
Others less experienced.
Old 09-17-2012, 10:15 AM   #21
He said he wants torque and we dynoed a supercoupe with a ported blower, pulley, and full bolt ons and it made 242whp and 317wtq also had a 75 shot but don't remember the hp and tq on that one and that set up is now on a 98 v6. Thats the only v6 I have worked on I usually work with v8
Old 09-17-2012, 10:59 AM   #22
The glass packs kinda like a cat that gives the exhaust back pressure
Old 09-17-2012, 03:59 PM   #23
Region: Arkansas
it's nothing like a catalytic converter....
blower/new cam soon
Old 09-18-2012, 04:26 PM   #24
94sccoupe's Avatar
Region: West Virgina
Tbird blower!!!!
94sccoupe is offline   Reply With Quote
02:56 PM
