bought lowering springs! - Mustang Evolution
Old 09-15-2012, 05:38 AM   #1
Bamman's Avatar
So last night I was on am looking at what they have new and I found myself a pair of lowering springs. And I found a cheaper pair at latemodelrestoration.com which a good site btw. And I bought a set of sve ajustable lowering springs and ill have them by Wednesday. Any tips on how to make the install easier? And ill be posting pictures asap!
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 09-15-2012, 09:37 AM   #2
1slosix's Avatar
Re: bought lowering springs!
Spring installs are a breeze in most cases...just have a set of wrenches, a prybar or big flat head, and a can of pb blaster
carving corners like a boss
Old 09-15-2012, 12:57 PM   #3
Bamman's Avatar
Pb blaster?
Old 09-15-2012, 08:55 PM   #4
1slosix's Avatar
Originally Posted by Bamman View Post
Pb blaster?
it's a penetrating spray...better then anything else i've ever used. usually next to the wd40
Old 09-15-2012, 10:33 PM   #5
Bamman's Avatar
Sounds good. They ship out Monday and get here by Wednesday, ill post pictures asap.
Old 09-19-2012, 11:34 AM   #6
Bamman's Avatar
They just came in like 10 min ago!
Old 09-19-2012, 04:00 PM   #7
davidcseifert's Avatar
Region: Arkansas
the SVE springs?
blower/new cam soon
Old 09-19-2012, 06:44 PM   #8
Bamman's Avatar
Yes sir.
Old 09-19-2012, 10:02 PM   #9
1slosix's Avatar
let us see the finished install..i've been curious how the sve ones sit
Old 09-19-2012, 10:46 PM   #10
Mike V.'s Avatar
I wanna see too!
Mike V. is offline   Reply With Quote
Old 09-19-2012, 11:07 PM   #11
Bamman's Avatar
Well me and my dad were supposed to install them tonight but "something came up" and now I have to hold it off till Saturday. But I will forsure post pictures.
Old 09-21-2012, 10:10 AM   #12
The SVE's sit low. Might run out of Camber. All depends on what else is installed too. I heard great things about those springs, for the price.
Old 09-21-2012, 11:20 AM   #13
Bamman's Avatar
I was worried about the whole camber thing, what all goes into that?
Old 09-21-2012, 04:59 PM   #14
Region: Arkansas
Just some new CC (caster/camber) plates will solve that problem
blower/new cam soon
Old 09-21-2012, 05:31 PM   #15
Bamman's Avatar
Do you know where to get those and a price?
Old 09-21-2012, 05:36 PM   #16
Horseplay's Avatar
any website sells them. am etc. should cost around 190 i think for the 4 bolt plates
Low2v
Old 09-21-2012, 05:38 PM   #17
Region: Arkansas
http://www.americanmuscle.com/maximu...tes-94-04.html
Maximum Motorsports has a very good reputation
blower/new cam soon
Old 09-21-2012, 05:51 PM   #18
Bamman's Avatar
Thanks for that I'm putting the springs in tomorrow and ill probably get an alignment for the front and get camber plates a little bit later down the road.
Old 09-21-2012, 05:53 PM   #19
Horseplay's Avatar
can an alignment still work without the cc plates? becuz i need one and havent bought plates yet
Low2v
Old 09-21-2012, 06:01 PM   #20
Region: Arkansas
Usually past 1.5" drop you need them
blower/new cam soon
Old 09-21-2012, 06:09 PM   #21
Horseplay's Avatar
**** ! i needa buy the damn plates then
Low2v
Old 09-21-2012, 06:12 PM   #22
Region: Arkansas
How far you drop it?
blower/new cam soon
Old 09-21-2012, 06:14 PM   #23
deadsp0t's Avatar
Not sure about the 6's but mine is lowered at least 1.5" and I have maximum Motorsports 4bolt CC plates and mine can't be aligned 100% perfect even with the plates. Has bump steer, needs x2's and bump steer kit to be aligned perfect.
Been driving on the same tires a year now and they look and feel fine but my car tracks left and right at times.
That's unimpressive
Old 09-21-2012, 06:23 PM   #24
Horseplay's Avatar
how do u measure the drop? i didnt measure the stock height before i dropped it. my front is dropped more than my rear
this is how my front sits
Low2v
Old 09-21-2012, 06:51 PM   #25
94sccoupe's Avatar
Region: West Virgina
I'm not happy with the drop the sve springs gave my car. I want lower. Thinking about cutting some off the new springs. They advertise them bn a 2" drop but that's meant for a v8
94sccoupe is offline   Reply With Quote
Old 09-21-2012, 07:04 PM   #26
Bamman's Avatar
mine are an 1.50 in the front and an 1.25 in the back. But I think they might have been the wrong springs they sent me. and it might drop it lower.
Old 09-21-2012, 08:53 PM   #27
Siendly22's Avatar
+10000
Siendly22 is offline   Reply With Quote
Old 09-21-2012, 11:00 PM   #28
1slosix's Avatar
give it a few weeks to let the springs settle before you align it...might i reccomend letting them leave it in the negative a degree or two if you're wanting something that hits the corners better...if you like straight lines 0 camber is best.
Old 09-22-2012, 04:45 AM   #29
Suspension work takes lots of research. I saved for 2 years, got the parts, then installed all at once. Time consuming, expensive, but the pay off is so great. It makes for a much safer car at high speeds. The V8 is 100lbs heavier. To get what I needed, I had to get the C/C plates, X2 balljoints, bumpsteer kit, along with shocks/struts and springs. Maximum Motorsports sold me the CC plates and bumpsteer kit. I cut one full coil in front, one 1/2 coil in rear.
Old 09-22-2012, 07:32 AM   #30
jdavis96gt's Avatar
Good street alignment 1 degree of negative camber, caster 4-5 degrees and toe at 0.
Old 09-22-2012, 07:41 AM   #31
Since yall wanna talk suspension, how do you put bumpsterrs on? Just mark out where the old ones were then simple remove and install?
Blackedout is offline   Reply With Quote
Old 09-22-2012, 09:00 AM   #32
deadsp0t's Avatar
Not simple at all. FastLane will be doing my entire swap on this particular project.
That's unimpressive
Old 09-23-2012, 01:52 AM   #33
Talking Re: bought lowering springs!
Bumpsteer kit, 1994-04 Mustang, tapered-stud style [MMTR-4] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
C?C platers & bumpsteer kit from MM. Steeda has that great X2 balljoint. Geta ll the parts and take it to your Mustang shop for alignment, NOT Midas or Minokee, goofy places. You'll love it. REMEMBER, A soft comfortable ride is a result of the rear progressive rates. Daily drivers want a low, softer number.
Old 09-23-2012, 07:22 AM   #34
So your saying i shouldnt install myself?
Old 09-23-2012, 09:02 AM   #35
Bamman's Avatar
So I attempted to do the lowering springs and I'm still not done we had to undo the whole A frame and drop the shock in order to get the new spring in. Is there an easier way?????
04:29 PM
