Quick question need a quick answer about exhaust manifolds - Mustang Evolution
Old 09-16-2012, 12:52 PM   #1
Ghostedmind's Avatar
I'm headed to the junk yard to pick up an exhaust manifold to replace the 1 that has cracked and i thought about getting the headers from the 94 to 98 model and I wondered if anyone had ever bolted them up to an 04 3.9L.
LCMC Member
Old 09-16-2012, 12:53 PM   #2
They bolt right up with no issues
Old 09-16-2012, 05:46 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: Quick question need a quick answer about exhaust manifolds
yes sir they do
blower/new cam soon
Old 09-16-2012, 07:12 PM   #4
sweet, I got them now I just have to take time to get them in all while moving. Joy Joy. Thanks for the input guys. Anyone know what kind of gains or whatnot i should get from switching from the old log manifolds to these headers?
LCMC Member
Old 09-16-2012, 07:26 PM   #5
Dgerow12's Avatar
Maybe slightly better flow and a bit better sound. They are the same as shortys not much is noticed from headers unless they are longtubes
Dgerow12 is offline   Reply With Quote
Old 09-16-2012, 08:40 PM   #6
ive always heard that the 94-98 headers are much better than the 99-04 manifolds
LCMC Member
Old 03-14-2013, 10:53 PM   #7
side note, they do bolt straight up to the block, however the flange on them is a little bit (maybe 1/4") bigger than on the stock new edge ones.
LCMC Member
Old 03-14-2013, 11:36 PM   #8
1slosix's Avatar
you are correct easy way to fix this is to take the collectors from an sn95 and weld them up to the NE's midpipe.
carving corners like a boss
exhaust
01:16 PM
