new cam? - Mustang Evolution
Old 09-17-2012, 03:54 PM   #1
mattyp511's Avatar
Region: New Mexico
new cam?
Hey guys I was looking into cams and was wondering how much HP I could get by adding a new cam thanks
mattyp511 is offline   Reply With Quote
Old 09-17-2012, 03:57 PM   #2
ColeJohnson's Avatar
Re: new cam?
JUST a cam? A cam plus retune(you'll need it) will probably get you around 25-35rwhp. Now if you add a higher-flowing intake manifold then expect gains over 70rwhp!
2016 Comp Orange GT (current)
Old 09-17-2012, 04:02 PM   #3
davidcseifert's Avatar
Region: Arkansas
Re: new cam?
cam alone, no other mods 15-20
if "intake manifold" includes ported heads, P&P lower intake and a windstar upper swap with full exhaust then sure lol
blower/new cam soon
Old 09-17-2012, 04:06 PM   #4
mattyp511's Avatar
Region: New Mexico
Sound s good to me
Old 09-17-2012, 04:07 PM   #5
Region: Arkansas
Re: new cam?
to give a more accurate estimation what all mods do you have done/will do with the cam?
blower/new cam soon
Old 09-17-2012, 04:29 PM   #6
mattyp511's Avatar
Region: New Mexico
Does any one know where to get a cam for a v6 ive been looking and can only seem to find em for gts
Old 09-17-2012, 04:39 PM   #7
Venomouz831's Avatar
I believe supersix motorsports sells thenm
)02 Gt, Founder of WE2G
Old 09-17-2012, 04:56 PM   #8
Region: Arkansas
Re: new cam?
I got mine from Kyle
Home - Kyle Person Performance
Paid ~250 for it back then
blower/new cam soon
Old 09-17-2012, 05:01 PM   #9
mattyp511's Avatar
Region: New Mexico
Well right now I just have lt headers dual flow master 40 cai an a tune...
---------- Post added at 05:01 PM ---------- Previous post was at 04:58 PM ----------
What's the damage about gonna be to have it installed any one know
Old 09-17-2012, 08:49 PM   #10
Region: Arkansas
Re: new cam?
hey that helps a good bit, more exhaust flow to let it breath
do it yourself? it's not terribly hard anyone who can comprehend a $30 repair manual can install it lol (granted you have the tools)
if you got someone else to do it i would assume200-300ish if you get a fair shop, depending on the aggressiveness of the cam will determine if you can limp it to a dyno or not to be tuned, also determines if you require new valve springs and pushrods
blower/new cam soon
Old 09-17-2012, 10:37 PM   #11
lemons95's Avatar
Re: new cam?
compcams.com should have everything you need for a cam swap.
Old 09-18-2012, 07:19 AM   #12
V6stang6272's Avatar
If you get a new cams then your going to have to get new pistons and rods and valves and o- rings unless you wanna put pressure on your engine causing it to blow
V6stang6272 is offline   Reply With Quote
Old 09-18-2012, 07:33 AM   #13
mattyp511's Avatar
Region: New Mexico
Thanks for all you're help everyone
Old 09-18-2012, 07:35 AM   #14
deadsp0t's Avatar
Not accurate at all.
What 'O-Rings' might you be referring to?
That's unimpressive
Old 09-18-2012, 07:52 AM   #15
How is that not accurate. It's common sense. Bolts ons help hp but don't at wreck the engine.
Adding just a certain part to your engine is stupid. That only causes more hp causing the engine to run harder when he steps on it so piston can blow ad screw up the whole engine.
I'm just saying if you wanna be able to thrash your gears and even gain more hp get what I said
Old 09-18-2012, 07:54 AM   #16
deadsp0t's Avatar
Adding a correctly spec'd cam will not 'blow your engine' this is tried and true fact.
That's unimpressive
Old 09-18-2012, 08:00 AM   #17
Yea but he wont gain anything special from it when he could put In a performance cams
Old 09-18-2012, 08:03 AM   #18
deadsp0t's Avatar
Ppl add E-cams to 5.0L push rod motors for years now with no issues. It is a performance cam.
Correction.. Decades not years..
That's unimpressive
Old 09-18-2012, 08:05 AM   #19
5.0 L. !! Not a 3.8 the 5.0 is a completely different set up
Old 09-18-2012, 08:06 AM   #20
deadsp0t's Avatar
Ok man.. You win.
That's unimpressive
Old 09-18-2012, 08:42 AM   #21
KATO's Avatar
Re: new cam?
I was kinda there with you too "deadspot", until he pointed out that it was a 3.8 V6, then I thought F%@$, he might be right about that.
Old 09-18-2012, 08:46 AM   #22
deadsp0t's Avatar
That's unimpressive
Old 09-18-2012, 08:50 AM   #23
Dgerow12's Avatar
You can put in a performance cam on a 3.8 v6 without changing out the pistons and rods. A cam controls the opening and closing on the valves allowing air/fuel in and exhaust out. Granted to get the best results from a cam you would need to port and polish the heads and intake and do a proper valve job. But you do not by any means NEED to change the pistons and Rods.
Dgerow12 is offline   Reply With Quote
Old 09-18-2012, 09:06 AM   #24
Region: Arkansas
Dear god honestly people?? You think a cam will f over a motor haha so I guess all those guys who throw 10+ psi (BOOST) on a stock motor must blow it sky high everytime they touch the gas pedal...
blower/new cam soon
Old 09-18-2012, 09:11 AM   #25
xhgwx's Avatar
+1000 on kyle
---------- Post added at 10:11 AM ---------- Previous post was at 10:08 AM ----------
I'll say this politely since star trek up there just gave me an infraction early, if you don't know what you're talking about shut your mouth (not at you deadspot, to make that clear -_-)
Hey David aren't you running a performance cam
On stock 4.2L internals?
xhgwx is offline   Reply With Quote
Old 09-18-2012, 10:04 AM   #26
Region: Arkansas
Re: new cam?
Originally Posted by xhgwx View Post
+1000 on kyle
Yes lol
blower/new cam soon
Old 09-18-2012, 10:15 AM   #27
RaysV6's Avatar
Send a message via Yahoo to RaysV6
I would like to say if ur looking into cams, from my research the lumpy cam from supersixmotorsports.com will also give u that v8 sound from ur v63.8. But along with that then ur car will have to get retuned. And from the sounds of it u already have a tuner in place... the lumpy cam will cost ib the ball park of $379.00, not vad for a cam that will help with rhe loudness of ur exhuast and not to mention the looks people willl give u when they realize that ur dricing a v6 not a v8
RaysV6 is offline   Reply With Quote
Old 09-18-2012, 10:40 AM   #28
xhgwx's Avatar
Yes lol
And have u blown ur engine yet on those stock internals?
Old 09-18-2012, 11:03 AM   #29
You wouldn't absolutely need new valves and pistons. But the cam is causing more a/ o ratio making the pistons to work harder. I was just stating if you wanted to keep the motor alive longer than 2 years. It work make the engine run better. Y'all are slaying my life haha
Old 09-18-2012, 11:17 AM   #30
Region: Arkansas
Re: new cam?
No I can't kill this ***** lol
Ratio doesnt increase the amount of mixture in chamber does..
Stock internals have been proven time and again to hold 350rwhp easily, and that's for a lot longer than 2 years
blower/new cam soon
Old 09-18-2012, 11:44 AM   #31
Yea stock internal that are maybe brand new.
For example it's just like saying a stock 2000 v6 mustang has 190 hp that's wrong because the unless the car has under 50,000 miles there's wear and tear.
How ever old the kids car is say 11 years old the internals are already beat to hell
Old 09-18-2012, 11:48 AM   #32
xhgwx's Avatar
I have 96k miles,
2003
Many people have done boosted set ups that last forever that have over 50k miles on them.
It's all about maintenance of the car.
Old 09-18-2012, 11:52 AM   #33
Well you guys can just guess that the kids previous owner took care of the car. My mustang is a 2001 v6 and my car has been beat to hell and somehow came back.
Old 09-18-2012, 11:53 AM   #34
xhgwx's Avatar
Mines been in my family since day one, regular oil am filter changes. And things as needed still runs strong.
Old 09-18-2012, 11:54 AM   #35
Region: Arkansas
Re: new cam?
Wrong again... You highly underestimate these little sixers lol everyone running around right now with boost and built top ends (ignoring those who have new forged internals) have a good bit of mileage on them and no problems, hell my 02 still had factory cross hatching in the walls at 118K miles and it started life as a rental car and has never had an easy life since..
blower/new cam soon
04:34 PM
