Idle air control valve - Mustang Evolution
Old 09-18-2012, 09:15 PM   #1
Can anybody help me my 2000 v6 3.8... When I give it a little gas before releasing the clutch on first gear the rpm stays at 2000 and won't go down unless I stop the engine.... I already replaced the tps and cleaned the idle air control valve
Mustang2000v6 is offline   Reply With Quote
Old 09-18-2012, 09:49 PM   #2
1slosix's Avatar
Re: Idle air control valve
did you clean the MAF?
carving corners like a boss
Old 09-18-2012, 10:01 PM   #3
Yep ive seen the MAF sensor dropp to 23 on the BARO,,and cause that,,after you clean it ,,disconnect the neg battery for about 10 mins,,reconnect and drive immediatly,,to reset the BARO..I have also seen the idle air bad and cleaning it doesnt help,,
---------- Post added at 10:01 PM ---------- Previous post was at 10:00 PM ----------
Are you sure the throttle plates arent sticking,,
mymustang is offline   Reply With Quote
Old 09-18-2012, 11:13 PM   #4
The maf? I cleaned the throttle body too... I'll clean the maf and see what happens thanks guys
11:30 AM
