winstar intake - Mustang Evolution
Old 09-19-2012, 12:01 PM   #1
Mystangv640th's Avatar
winstar intake
Can any please give me info on a windstar so i can go to my local junkyards i have a 04 mustang 3.9.. what year and car can i look for to get the windstar intake and what else i need to install..
Mystangv640th is offline   Reply With Quote
Old 09-19-2012, 03:55 PM   #2
davidcseifert's Avatar
Region: Arkansas
Re: winstar intake
you get it from the 96-98 year model vans
grab the intake itself
the egr bracket (sits between egr valve and lower intake) you'll need this if you plan to keep egr since it requires a lower bracket with this intake
the throttle body
and you can grab the IAC if you want, but the question is do you have a taller hood or do you plan to remote mount the IAC for it to work?
blower/new cam soon
Old 09-19-2012, 07:23 PM   #3
mustangg2000's Avatar
Region: Arkansas
David how you remote mount the IAC?
mustangg2000 is offline   Reply With Quote
Old 09-20-2012, 12:38 AM   #4
Region: Arkansas
Re: winstar intake
you have to make a bracket to hold it somewhere else, then attach a fitting to the intake to run a line to IAC for the air discharge and then run a line to the intake pipe for the air the IAC needs to suck in VAP has pictures of everything so you have an idea of what you have to make
blower/new cam soon
Old 09-20-2012, 08:22 AM   #5
Re: winstar intake
I already have a windstar but just out of curiosity does the length of the hoses you use to achieve this effect the i.a.c operation in any way? For a radical example say if i wanted to extend the harness and vac lines to my trunk would it still work the same or is there a limit to the amount of hose you can use?
l2plagears is offline   Reply With Quote
Old 09-20-2012, 10:32 AM   #6
Region: Arkansas
Yeah I don't think it would idle right from back there lol keep it generally close to the front of the motor and nothing should happen
blower/new cam soon
12:33 PM
