how much gas for seafoam - Mustang Evolution
Closed Thread
Old 09-20-2012, 09:42 AM   #1
How much fuel should i have in the tank before using a can of seafoam?
l2plagears is offline
Old 09-20-2012, 09:46 AM   #2
Dgerow12's Avatar
If you use it in your gas then I would put it in when you fill up so it gets mixed into the gas good
Dgerow12 is offline
Old 09-20-2012, 09:46 AM   #3
Bamman's Avatar
Run your tank down till its almost at E then put the sea foam in and full your tank back up.
8 Cylinders Little Brother.
Bamman is offline
Old 09-20-2012, 10:02 AM   #4
Re: how much gas for seafoam
What if i was gonna do thirds vac/tank/crankcase
Old 09-20-2012, 03:56 PM   #5
Bamman's Avatar
Divide it up or wait another few hundred miles.
Bamman is offline
Old 09-20-2012, 05:27 PM   #6
Mike SVOR's Avatar
About 1 cap-full per full tank of gas.
1999 3.8 stang
1990 LX - supercharged 351w
1985 turbo 2.3 www.msvorinich.itgo.com
Mike SVOR is offline
Old 09-20-2012, 09:27 PM   #7
1slosix's Avatar
if you arent' going to help in this section can you take it to the bar section
OP even on the third method you'd want 1/4 tank minimum
carving corners like a boss
1slosix is offline
Old 09-20-2012, 09:53 PM   #8
Bamman's Avatar
Do you know how big the top is on a seafoam bottle?
Bamman is offline
Old 09-20-2012, 09:58 PM   #9
1slosix's Avatar
he knows..he's just trolling the thread because it's about a product he's never used. he does it in all the seafoam threads
1slosix is offline
Old 09-20-2012, 10:51 PM   #10
Mike SVOR's Avatar
Trolling is an attempt to deceive. I intend to protect forum members from damaging their cars and property.
I've never used Alabama clay in my gas tank either, but somehow I know it's not a good combination with my fuel system.
OP, pls do some research on this product before you even purchase it. Your money is best spent in fuel filters and other tune up products.
1999 3.8 stang
Old 09-21-2012, 06:15 AM   #11
BigT03's Avatar
OP, I used Seafoam in my car and it dd nothing but mess up my motor. I'm having to go thru Seafoam to see if they'll cover the repairs. I'd have a shop do the work so if it messes up the shop has to fix it.
'Arion' 2001 Mustang V6 5sp
I am Big-T, and I approve this car!
BigT03 is offline
Old 09-21-2012, 06:57 AM   #12
Bamman's Avatar
Ok so your saying to put a very small amount into his gas tank every time he fills it up? And how is a fuel filter gonna clean out injectors port heads ect... like sea foam does?
Bamman is offline
Old 09-21-2012, 07:56 AM   #13
davidcseifert's Avatar
Region: Arkansas
Did you really just say port heads with seafoam?!?!?!
blower/new cam soon
davidcseifert is offline
Old 09-21-2012, 08:55 AM   #14
Mike SVOR's Avatar
Pouring seafoam in your gas tank to clean your injectors, ports, heads, etc... is the same as leaning against a wall thinking it will iron your clothes.
If you have clogged injectors, you need to take them apart and clean them (or have a shop do it).
Try running better gas in your car for starters.
1999 3.8 stang
Old 09-21-2012, 09:38 AM   #15
deadsp0t's Avatar
Bottom line is some swear by products like this, Marvels Mystery Oil and many others and some swear these products have hurt or destroyed their engines.
Chances are some misuse the products or didn't need them to start with. Logic dictates that the reputable products sold world wide will not destroy your engine if used per the directions, not per word of mouth. I think we have herd plenty of OPINIONS and THEORIES from both sides.
USE THESE PRODUCTS AT YOUR OWN RISK.
That's unimpressive
deadsp0t is offline
Closed Thread
04:20 PM
