Reverse Glow Gauge Installation - Mustang Evolution
Old 09-20-2012, 06:24 PM   #1
Hey everybody,
I am about to install Reverse Glow Gauges in my car and I had a small concern, really a brain fart. The Reverse Glow Gauges have a dimmer switch on them and I am not sure how to mount it. Will I need to drill into the dash to find somewhere for it to go? Anyone out there with Reverse Glow Gauges that can give some guidance? Thanks....
devanslive is offline   Reply With Quote
Old 09-20-2012, 06:52 PM   #2
Dantheman94's Avatar
Sorry I'm not really a help but I just bought probably the same set of gauge covers and ill probably install them tomorrow so if I figure something out I'll let u know
Dantheman94 is offline   Reply With Quote
Old 09-20-2012, 07:03 PM   #3
Re: Reverse Glow Gauge Installation
Sounds like a plan... LoL... Thanks
Old 09-20-2012, 09:24 PM   #4
1slosix's Avatar
my switch is behind the cluster..honestly keeping it on high is the best overall look. it's not as bright as you'd think
carving corners like a boss
Old 09-20-2012, 11:22 PM   #5
johnofarch14's Avatar
Send a message via Skype™ to johnofarch14
Same thing as mine, that's what i did. You don't need to drill holes.
johnofarch14 is offline   Reply With Quote
Old 09-21-2012, 04:29 AM   #6
Okay, so you guys just stashed it behind the cluster. Did you guys solder the wires or crimp them and for the ground did you drill into the chassis or splice into the ground wire on the headlight switch harness? Thanks....
Old 09-21-2012, 05:03 AM   #7
9tee7pony's Avatar
For that I added a longer wire and ran it down to a screw on the fuse box under the dash. And for the dimmer switch I have it hanging out between the air vent and the steering wheel. I have 2 wires coming from out of my dash, but it really doesn't bother me.
9tee7pony is offline   Reply With Quote
Old 09-21-2012, 05:18 AM   #8
Okay, so you added another wire to the black ground. I cannot tell what kid of gauge the black wire is in order to get a matching wire to add length. If I am not mistaken isn't the fuse box plastic? Thanks
Old 09-21-2012, 12:33 PM   #9
9tee7pony's Avatar
I just took an old electronic and cut the cord. The fuse box is plastic, but the screws are metal and it worked.
Old 09-21-2012, 01:30 PM   #10
So you did not have an issue with the wire you added having all the different gauges or smaller wires? The black ground wire on the gauge looks like it is just one copper piece in the middle.
Old 09-21-2012, 01:48 PM   #11
9tee7pony's Avatar
Nope all you need for current to flow is metal to metal contact. Just make sure the connection point holds.
Old 09-21-2012, 11:08 PM   #12
1slosix's Avatar
behind the cluster on the right side there is a bolt going into the big bar behind the dash...i unscrewed it and grounded my wire there...it works like a charm
Old 05-13-2013, 02:20 PM   #13
ProjectTurboV6's Avatar
What about the red wire?? Does that go into the thick brown wire or thin grey one?? I'm installing now and ran into this hindrance. Where the grey wire is supposed to be, mine is Brown... Still I'm the same place and same size wire... Doesn't light up though...
ProjectTurboV6 is offline   Reply With Quote
Old 05-13-2013, 11:47 PM   #14
1slosix's Avatar
use the brown wire then...could just be due to the model difference
Old 05-13-2013, 11:49 PM   #15
I did, everything works fine except for the speedometer :/
Old 05-13-2013, 11:52 PM   #16
1slosix's Avatar
use a test light to see where it's losing fire.
Old 05-27-2013, 03:11 PM   #17
Could it be the fact that I got the GT insert and not the v6? -_-
» Members Mustangs
Sally
Fryes
Steve96
Add your Mustang
07:40 PM
