anyone swap to 4.3 liter - Mustang Evolution
Old 09-23-2012, 06:20 PM   #1
Has anyone here swapped to the 4.3 liter? Can you compare it to the 3.8 for me?
Blackedout is offline   Reply With Quote
Old 09-24-2012, 11:19 PM   #2
1slosix's Avatar
my friend did...it was quick even with the stock rear end and 3.27's...wish he would have put in gears and a tlok before selling it
carving corners like a boss
Old 09-25-2012, 01:25 AM   #3
DaBluedude's Avatar
There's a kid in town who did this swap. He made 178rwhp. He then added a 03 cobra blower. Then he made 171hp. That's not a typo. His tuning is mucked. He's in for way more money than its worth.
2003 Mach 1
Old 09-25-2012, 05:54 AM   #4
Im thinking of getting the motor from supersixmotorsports. Ill save up and just have all motor c/h/i. And a set of 4.10 gears
Old 09-25-2012, 06:05 AM   #5
xhgwx's Avatar
Hmm, just the swap? No upgraded parts like cam? Heads? Stuff like that? Once I'm done with my H/C/I, LTs, X-Pipe, T-Lok and 4.10s I should be making 220-240rwhp
xhgwx is offline   Reply With Quote
Old 09-25-2012, 09:07 AM   #6
DaBluedude's Avatar
I don't know for sure about cam but he did a little work on the heads. It isn't worth it. I'm a V8 guy. It's cheaper and easier and is a better platform from there in my eyes. I know you can make crazy 6 cars. But the drive ability goes down fast.
2003 Mach 1
Old 09-25-2012, 12:51 PM   #7
xhgwx's Avatar
This is also true, after I'm
Done I'll see 16-17 city and 13-16 HW.
But mine was given to me so I can't complain at what I got, I'll just make it into something I want.
Next mustang will be a v8 tho.
Really want a fox body
Old 09-25-2012, 05:14 PM   #8
lemons95's Avatar
I hope not. the 4.3's a chevy engine...
if your talking about a 4.2 bored out to 4.3 though
a stock 4.2 is suppose to be making around 220.
Me and my dad just finished mine a couple weaks ago we have just a little less then 150miles on the engine.
I still have the singleport heads but theres a noticeable power difference in it. I also used the cam that came with the 4.2 I don't know how much of a difference that made though.
Old 09-25-2012, 06:07 PM   #9
97cutomstang's Avatar
I can just get my 3.8 block bored out to a 4.2 right?
97cutomstang is offline   Reply With Quote
Old 09-25-2012, 06:19 PM   #10
xhgwx's Avatar
Yes, u can even bore it to a 4.3
Old 09-25-2012, 06:27 PM   #11
lemons95's Avatar
thats kinda pushing it though.
you could stroke and bore it out more though like 4.4. I've seen one 4.5 I think stroked to 4.2 and bored to 4.3 would be the safest.
Old 09-25-2012, 06:59 PM   #12
What is the difference in stroking vs boreing?
Old 09-25-2012, 09:33 PM   #13
1slosix's Avatar
something is wayyy off..even on a stock 4.2 build my friends m112 swap made over 300
Old 09-25-2012, 09:34 PM   #14
xhgwx's Avatar
Ur alive! How was insanity?
Old 09-25-2012, 10:08 PM   #15
Kingmidas87's Avatar
Stroking it basically is putting a longer connecting rod in to lengthen the travel of the piston. Boring refers to putting a piston with a bigger circumference in the cylinder. Your cc is Bore x Stroke. Bigger bore and stroke = more cc/liter = more power.
Kingmidas87 is offline   Reply With Quote
Old 09-25-2012, 10:13 PM   #16
Sorry I kinda lied. When stroke a motor you get a crank that makes the stroke longer. Some times you can use the same length connecting rods but some kits might give you different connecting rods. Stroke kits will always have a stroked crank. I would of deleted and rewrote the comment above but couldn't.
Old 09-25-2012, 11:25 PM   #17
xhgwx's Avatar
But with a longer stroke you need a lot of different things so you don't come in contact with the heads?
Old 09-25-2012, 11:43 PM   #18
Yeah that's wear the different length connecting rods come in.
Old 09-26-2012, 05:11 AM   #19
Ok good to know. My plan is to use my 3.8 block, a 4.2 crank, 3.8 connecting rods and 4.2 pistons. Is that go in the right direction?
Old 09-26-2012, 08:00 AM   #20
davidcseifert's Avatar
Region: Arkansas
Drivability going down? I guess you're referring to the mileage I daily drive my little 242rwhp sixer and no problems.. Just average 16mpg which if you're worried about gas mileage modding cars is not for you lol
A stock 4.2 makes ~202 crank hp
To get a true 4.3 you must bore a 4.2 motor over .050" which is not the best of ideas if you plan a stupid amount of boost
They have the same block.. Why not just pull a 4.2 from an f150 and call it a day, less work and hardly ever have to rebuild them
blower/new cam soon
Old 09-26-2012, 08:08 AM   #21
That was my original plan but finding a 4.2 around me is hard. I saw one once at a junk yard and that was it. It's going to be my winter project so I'm just going to take my time and rebuild the motor. Since they are the same block the 4.2 pistons will fit in my block right? Or do I have to have the cylinders bored out to fit the 4.2 pistons?
Old 09-26-2012, 08:17 AM   #22
Region: Arkansas
Also look for freestar vans they have 4.2's
The 4.2 and 3.8 have the same 3.81" bore factory just the 4.2 has more stroke, but you really have to be careful swapping out internals if you block is in good enough shape that it doesn't require anything more than honing it should be ok with different rings
For the ease of install its easier to just wait on a whole motor...
blower/new cam soon
Old 09-26-2012, 08:25 AM   #23
Ok I'll have to keep an eye out for them. Thanks.
04:18 PM
