Wheel spacers - Mustang Evolution
Old 09-29-2012, 05:39 PM   #1
98mustang11's Avatar
Wheel spacers
O save some money I'm getting 05 gt rims and tires from a relative for 400... What size wheel spacer would I need to make the rims look good on my 98 Amd not dumb
98mustang11 is offline   Reply With Quote
Old 10-01-2012, 06:39 PM   #2
twotone01's Avatar
I've mostly seen 30mm on people's but spacers scare me haha and I don't want to have to cut the studs for the lugs
twotone01 is offline   Reply With Quote
Old 10-01-2012, 08:56 PM   #3
1slosix's Avatar
i don't like spacers unless you're putting in longer studs as well...i would assume a 1/4" would be good enough, but you won't be flush
carving corners like a boss
Old 10-01-2012, 09:59 PM   #4
They got an 1.5 for like 120 and 1" for 100... Iv got em on they don't sit to far in I just read you would have to have them so they wouldn't look bad... I'm not sure if you can tell on this pic....
Old 10-01-2012, 10:02 PM   #5
This pic
Old 10-01-2012, 11:45 PM   #6
twotone01's Avatar
I read that the hubcentric spacers won't work on factory wheels
Old 10-02-2012, 01:37 AM   #7
The two I look At on am have the studs on them already
Old 10-02-2012, 01:53 AM   #8
twotone01's Avatar
The H&R ones?
Old 10-02-2012, 01:14 PM   #9
I was looking At the billet aluminum but yea those to
Old 10-02-2012, 01:21 PM   #10
twotone01's Avatar
I've heard not to get them because they aren't hubcentric and can cause a vibration of not put on straight, also those put a lot more stress on the lugs, this Is just from what I've heard. I have no experience with wheel spacers but I'm looking for some as well
Old 10-02-2012, 06:45 PM   #11
1slosix's Avatar
you heard wrong...hubcentrics are the only spacer i'd truely trust
Old 10-02-2012, 06:51 PM   #12
twotone01's Avatar
On AM the H&R spacers say they won't work on factory wheels but you're right, the 25mm won't work with stock wheels but the 35mm will fit both factory and aftermarket
http://www.americanmuscle.com/h-r-spacers-25mm.html
Old 10-02-2012, 07:27 PM   #13
1slosix's Avatar
yeah i've only dealt with 35mm...honestly i forget about the 25mm ones
Old 10-02-2012, 07:45 PM   #14
twotone01's Avatar
What's the center bore on our axles because I'm looking at the 35mm ones and I'm not sure of the center bore thing on the axle. Or is that not important?
07:01 AM
