Engine swap to 4.6 - Mustang Evolution
Old 09-30-2012, 12:54 PM   #1
Zombiefro's Avatar
Engine swap to 4.6
Hey everyone, So I have a buddy with a 4.6 4v 2001 Cobra Stock Motor and Trans
Currently I have a 2000 V6 Automatic , I was wandering two things.
1. Is it worth it/possible to do this switch and what would I need to make it happen
2. Am I better off supercharging the V6?
Any positive advice is appreciated, def checking back to see some responses.
Thanks!
Zombiefro is offline   Reply With Quote
Old 09-30-2012, 01:03 PM   #2
xhgwx's Avatar
Thanks!
The motor and trans is the most expensive things of the swap, now u need an 8.8 rear end.
Computer and wiring harness K member I believe. Oil pan. Motor mounts
Pretty much need everything. Also get cobra gauges etc.
Supercharged v6 may make 300rwhp
And unless u build the engine u won't ever get past 400 safely
The cobras make 400 crank but in most cases make that on a dyno, they were under rated by ford.
Pretty much what ever is on that car u need to swap
But it's a great engine GL
xhgwx is offline   Reply With Quote
Old 09-30-2012, 04:03 PM   #3
Zombiefro's Avatar
Thanks for the quick response! Glad to hear because I honestly was leaning towards the engine while my brother was leaning towards the supercharge
Old 09-30-2012, 04:56 PM   #4
You should supercharge. I thought about swaping the 4v swap. But, thats a lot of work. While your just taking a motor out forging the bottom end and do it right youll have a decent amount of hp or that compared to rewireing and streightnening your car. Bc the v8 had a stronger chasis, with stabbalizer bars and etc, then wireing the computer. Unless you wanna be out of a car for a good long time id just consider buying a v8 or just putting more steel on that v6. The choice is yours.
---------- Post added at 04:56 PM ---------- Previous post was at 04:56 PM ----------
Anybody correct me if im wrong...
Blackedout is offline   Reply With Quote
Old 09-30-2012, 05:04 PM   #5
Now, what i wanna do is forge my bottom end, cam head and intake. Bore to 4.3, then turbo.
Old 09-30-2012, 05:21 PM   #6
Wait a minute. If im turboing. Wtf am i thinking about longtube headers for. Lol
Old 09-30-2012, 05:37 PM   #7
ForsakenProto's Avatar
Thanks!
Ive got a 4.6 Teskid block out of a 97 mark VIII. Your best bet would be to trade the sixxer for an 8 with high miles or a blown engine and swap the new 4.6 into it. Saves alot of work and can re use almost all the gt parts in the swap.
ForsakenProto is offline   Reply With Quote
Old 09-30-2012, 06:20 PM   #8
Keep in mind is this something you really wanna do. Bc if you hit a problem during your planinng youll be thrown in all kinds of directions. So.. its up to you. Also, keep in mind theres people here who can help no matter what you decide.
Old 09-30-2012, 11:16 PM   #9
xhgwx's Avatar
I don't think u wanna bore to a 4.3. Walls would be to thin.
You want to stroke it to a 4.3
Old 10-01-2012, 06:27 AM   #10
Still doing my research...
Old 10-01-2012, 09:31 AM   #11
End up thin like this?
Old 10-01-2012, 07:24 PM   #12
Zombiefro's Avatar
Thanks for all the feedback it is a tough choice to either decide supercharge but if I do go engine after reading here it seems like the donor gt would be the way to go for that
Old 10-02-2012, 04:01 AM   #13
He wouldn't be out of the car for that long honestly as long as he knows what he's doing. I've swapped entire harnesses within a few hours of work... the motor/trans pull/install be the more time consuming part but to unhook/label everything... wouldn't take that long. the actual removal would be the pita
i'd say supercharge it though
Black_Sunshine is offline   Reply With Quote
Old 10-02-2012, 07:48 AM   #14
Im here if you need removal/installation and wiring help. I've got access to all of Fords wiring diagrams and stuff for most makes and models
04:49 AM
