Help, need more horsepower. - Mustang Evolution
Old 09-30-2012, 08:09 PM   #1
jleber123's Avatar
Anyway to help my poor V6 to get more hp? I'm a little bit of a newbie and asking you fellow mustang owners
jleber123 is offline   Reply With Quote
Old 09-30-2012, 08:34 PM   #2
Kingmidas87's Avatar
Just a food for thought, I was reading up on gains for our sixxers and its seems that "Horse power" gains are kinda pointless unless you get a race crank and bump up your rev limiter. Our cars make torque up to around 5000 I think and they redline between 5200-5400. So really you only have between 200-400 rpm to make horse power gains. Your best bet would be to focus on torque, which is more important anyway. You raise torque, you'll raise HP. I think if you can afford it start off with a tuner from AM. It will make a difference on a even a stock car and you can retune for every mod addition after that, getting the most outta every part. If you want it "quicker" then go with weight savings. Rear seat delete, aluminum drive shaft, aluminum flywheel(not for everyone so research it), etc. a regular CAI will give you throttle gains but the pre-tune affect of a CAI is argued. There IS a deference between a rack dyno and butt dyno, if you notice a difference I think it's worth it. You can just throw in a cam and get good gains from it.
Kingmidas87 is offline   Reply With Quote
Old 09-30-2012, 08:48 PM   #3
lemons95's Avatar
Oh there is plenty of stuff to get more horse power.
I guess a Cold air intake and tuner would be a good start.
Old 09-30-2012, 09:13 PM   #4
jleber123's Avatar
Well I'm planning on buying them. What else is there to purchase? I was looking around and saw something that said there aren't many aftermarket pieces to buy for a mustang V6
Old 09-30-2012, 10:02 PM   #5
lemons95's Avatar
there is plenty of aftermarket for are V6's. M112's, Turbos, Prochargers, Headers, Cams(these are really neat especially the lumpy cam from super six motor sports)
Then theres Tom moranas Tom Morana Racing Engines
Super six motorsports Super Six Motorsports - V6 products that make your life faster
and mysteed Mysteed Performance: Making the Impossible, Possible.
Old 09-30-2012, 10:22 PM   #6
Instead of thinking about gaining horsepower, you can think of it also as relieving horsepower... Stuff like Under drive Pulleys, aluminum drive shaft, better intakes don't necessarily give you horsepower, they simply free up the horsepower or make the car more efficient. You can also get a power increase feel from weight reductions, the aluminum drive shaft will reduce rotational weight. Just keep these things in mind, its not always mods for power that will make your car faster.
Old 10-01-2012, 06:29 AM   #7
xhgwx's Avatar
TMA Turbo
I highly recommend
Kylepersonoerformance.com
He does his work as a side job and is as good if not better than the places listed above and cheaper
xhgwx is offline   Reply With Quote
Old 10-01-2012, 03:20 PM   #8
davidcseifert's Avatar
Region: Arkansas
Yes Kyle would get you lined out pretty well for a good price, he's doing my motor work
blower/new cam soon
Old 10-01-2012, 08:59 PM   #9
1slosix's Avatar
i agree Kyles work is top notch...but really think about what you want out of the car OP...think of an exhaust first...something to keep you smiling as you drive while you consider where you want to end up.
carving corners like a boss
Old 10-02-2012, 01:36 PM   #10
Region: Arkansas
+1
blower/new cam soon
Accel-erate Your 2011+ Mustang’s Horsepower with Coil-On-Plugs! AMDanBailer 2011-2014 Mustang GT 13 01-11-2012 09:00 PM
Horsepower Ernest89Notch 1979-1995 Mustang GT 6 12-24-2011 04:56 AM
2011 5.0L Mustang vs 5th Gen Camaro - BBK Horsepower Challenge with Jessica Barton Napoleon85 2011-2014 Mustang GT 47 12-23-2011 10:18 PM
9 Mustangs and 7,176 Horsepower on the Dyno & Track AMDanBailer AmericanMuscle 0 11-16-2011 04:22 PM
6 Cylinder Horsepower Tuch65 Classic Mustangs 9 08-16-2011 04:36 AM
10:02 PM
