No Go on Reverse Glow!!! - Mustang Evolution
Old 09-30-2012, 10:41 PM   #1
Okay guys I need your help. I am still on my DIY kick. I got my reverse glow gauge inserts from Stack Racing and was excited. I installed everything exactly how it was supposed to be, with the exception of the ground. I used the screw that goes into the metal part of fuse box as the ground. I started the car and the regular headlights works, the regular gauge cluster lights works, but the reverse glow gauges do not. What am I missing? Please help guys!!!
devanslive is offline   Reply With Quote
Old 10-01-2012, 02:11 AM   #2
See the pic. That is not the reverse glow working. It looks like the regular cluster lights coming on behind it. The reverse glow should work independant of those, right?
Old 10-01-2012, 05:39 PM   #3
sam62893's Avatar
I think that the reverse glow lights should replace the regular lights. Well I'm not entirely sure but that's what I think.
Old 10-01-2012, 05:53 PM   #4
I have gauges like this in my 93, I just wired them separately with a switch.
Old 10-01-2012, 05:58 PM   #5
Venomouz831's Avatar
Did u get a little knob?
)02 Gt, Founder of WE2G
Old 10-01-2012, 06:56 PM   #6
Yes there is a little dimmer switch.
Old 10-01-2012, 06:59 PM   #7
My switch went bad I'm just using a toggle switch, or it could be the inverter went bad or they sent you bad inverter
Old 10-01-2012, 08:58 PM   #8
1slosix's Avatar
did you turn the dimmer all the way up? honestly you're ground wiring probably isn't good enough...where did you wire the power to? i ran mine to the cluster power wire, and the ground to the bar behind the dash
carving corners like a boss
Old 10-02-2012, 03:26 PM   #9
I ran my red wire from the 12V on the cluster cover to the headlight switch connector, middle grey wire according to the instructions from Stack Racing
---------- Post added at 05:26 PM ---------- Previous post was at 05:26 PM ----------
Yes, there is a little dimmer knob.
Old 10-02-2012, 03:36 PM   #10
Hmm idk what can be wrong if you did all the steps correctly. I just mine a few days ago and work fine, there's got to be a cable that isn't making the connection
Old 10-02-2012, 04:02 PM   #11
What year is your Stang and you did your black wire to the ground from the headlight connector, but where did you plug your red wire from the gauge insert to? Did you bolt your ground to the chassis behind the cluster? I do not have any rill bits that go through metal. Any other options fr grounding points? Thanks... by the way, did you solder your wires.
Old 10-02-2012, 04:07 PM   #12
I have an 02 gt. I did the ground behind the cluster bolted it with a bolt to some metal. The red I believe had to be connected to the gray wire in the center of the connector. Look at the instructions American muscle gives you. Try drilling into the chassis, and I spliced them
Old 10-02-2012, 06:35 PM   #13
1slosix's Avatar
im guessing your ground isn't good enough
Old 10-02-2012, 10:14 PM   #14
Siendly22's Avatar
I just did mine 2 hours ago! I like it so much
Siendly22 is offline   Reply With Quote
Old 10-03-2012, 04:51 AM   #15
I got mine to work now as well, but now they only come on when parking light are on and my parking light and headlights no longer come on at the same time.
Old 10-04-2012, 11:15 PM   #16
1slosix's Avatar
Originally Posted by Siendly22 View Post
Attachment 70963
those look like my old El Glows...what are they brand wise?
Old 10-05-2012, 05:46 PM   #17
Siendly22's Avatar
Do you have a picture on your "old one" ?
Old 10-05-2012, 10:05 PM   #18
1slosix's Avatar
sure do...these are el glow gauges (which can shift different shades of blut and green), and lunar autometer pod gauges...
this is what i wish i had again but i sold these gauges after crashing the car, and well i never thought i'd own a sixxer again. now i can't find them online
since i can't find el glows anymore i bought a set of these but i dont like them as much
Old 10-05-2012, 10:20 PM   #19
Siendly22's Avatar
I don't like the 2nd image. Mine is 2 colors too , blue and green. Their look nice at night
Old 10-05-2012, 10:25 PM   #20
1slosix's Avatar
yeah the reverse glows i have now are the AM ones. not my cup of tea, but better then stock since i love white face gauges. the day i find el glows again im jumping on them
Old 10-05-2012, 10:29 PM   #21
Siendly22's Avatar
Yea better than stock... Hehe.. JK bro
mark and i are the same white face gauge man..
Old 10-05-2012, 11:07 PM   #22
Have looked a mustangsunlimited.com?
I think they have El Glow gauges
Old 10-05-2012, 11:21 PM   #23
1slosix's Avatar
not on their website at least
Old 10-05-2012, 11:37 PM   #24
Hmm request a catalog, they're free and nice to have around
Old 10-06-2012, 12:20 PM   #25
The first set of gauges you had were really nice. Shame you can't find them again.
---------- Post added at 02:20 PM ---------- Previous post was at 02:19 PM ----------
Mine are AM gauges to. I thought about getting the chrome rings to go around them, but I opted against it.
Old 10-06-2012, 11:20 PM   #26
1slosix's Avatar
yeah the moment i find el glows i'm buying them no matter the cost. i was thinking about buying a full autometer cluster just so i can have that look again
Old 10-07-2012, 10:11 AM   #27
Hey 1slosix check out this website
99-04 Mustang V6 EL Glow Gauges
Old 10-07-2012, 02:32 PM   #28
willrad00's Avatar
i really like those bottem guages, whered you get them?
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 10-07-2012, 03:16 PM   #29
www.americanmuscle.com
09:41 PM
