forged bottom 3.8 - Mustang Evolution
Old 10-01-2012, 11:22 AM   #1
forged bottom 3.8
What could i expect with a forged bottom end c/h/i twin turboed build? Has anyone done this?
Blackedout is offline   Reply With Quote
Old 10-01-2012, 11:33 AM   #2
without forged internals, keeping it safe, with a good turbo setup and the upgrades needed to push 11-12 psi (intercooled) you should see 330rwhp~ not sure on tq but around there~ maybe more.
forged bottom end so you can up the boost, maybe lower compression around 8.5:1 youl would of course see more, not sure where the block would give out, but I would probably keep it under 400rwhp for daily driving, the block might take much more though not sure.
Old 10-01-2012, 12:38 PM   #3
Ill settle for 300 hp and tq. So your saying i eouldnt need a forged bottom end? At a safe psi
---------- Post added at 01:38 PM ---------- Previous post was at 01:38 PM ----------
Doing my research at the same time
Old 10-01-2012, 01:37 PM   #4
a friend of mine ran a single turbo setup (11-12psi) and ended up with 300-330rwhp on his 01 V6 3.8L with the stock motor. I think it eventually let go, but he had it for a long time. The KEY is the tune of course and having enough fuel etc.
If all you want is 300hp/tq might be far cheaper to sell your car and put that money (which will add up to be a good bit) towards something with 300hp stock to start with~ just one way to go.
Old 10-01-2012, 01:46 PM   #5
300 hp is what i want in this car
---------- Post added at 02:46 PM ---------- Previous post was at 02:45 PM ----------
I thought about selling it but i want two. V6 with v8. My two cars.
Old 10-01-2012, 03:18 PM   #6
davidcseifert's Avatar
Region: Arkansas
No need for twins really.. But 11psi is a general DD number it's not much of a heart ache on one lol (generally 350-375rwhp is what people recommend for a long life, over that its getting touchy)
With H/C/I you can get up to 230's alone easy, throw boost on top of that 7-8psi tuned right would get 325-350
blower/new cam soon
Old 10-02-2012, 05:15 AM   #7
Bigger fuel pump and injectors right? And is there any holes drilled in the motor at all?
Old 10-02-2012, 01:36 PM   #8
Region: Arkansas
Yes 10-11 psi get some cobra injectors (39/42's) and an Svt focus pump will be enough to play with
And you drill a hole in oil pan for turbo oil return line
blower/new cam soon
Old 10-02-2012, 02:53 PM   #9
The injectors thats what theyre called #/#?
Old 10-02-2012, 09:15 PM   #10
Region: Arkansas
eh some call them 39# injectors others 42#'s, but either way they'd be enough to support 300-350rwhp, that is with the pump
here are some, that's about the average price from what i've seen
03 04 4.6 dohc supercharged Mustang Cobra 39 39lb fuel injectors .SVT 99-01 | eBay
check corral.net, they have a wonderful classifieds section and good prices usually
blower/new cam soon
Old 10-03-2012, 04:52 PM   #11
mustangg2000's Avatar
Region: Arkansas
Or you can get a oil filter sandwich adapter for feed and return lines..
mustangg2000 is offline   Reply With Quote
Old 10-07-2012, 10:16 AM   #12
Got a picture of that
Old 10-08-2012, 10:29 AM   #13
Region: Arkansas
Sorry took a bit to respond
Old 10-08-2012, 04:08 PM   #14
I thought thats what that was thanks man
Old 10-08-2012, 04:56 PM   #15
Region: Arkansas
No problem bub
Old 10-08-2012, 05:06 PM   #16
Region: Arkansas
They make a mist kit that's methanol and water from snow performance that will keep your engine cooler so you can run a bigger boost and it not affect the engine
• Provides better fuel economy (1-3 MPG), more power (50-100 HP), and lower EGTs (150°-300° F)
^ off snow performance site ..
Old 10-08-2012, 05:21 PM   #17
Yeah american muscle sells
Old 10-08-2012, 05:23 PM   #18
Region: Arkansas
Ight cool
Old 10-08-2012, 05:52 PM   #19
I need pictures of the v6 motor with heads and intakes removed
---------- Post added at 06:52 PM ---------- Previous post was at 06:52 PM ----------
Need to see how the cam goes in
Old 10-09-2012, 10:59 AM   #20
Region: Arkansas
Meth injection isn't really necessary unless you're doing an M112 and you can't intercool it, otherwise a normal intercooled turbo/SC runs pretty cool
blower/new cam soon
10:55 PM
