Functional gt scoop - Mustang Evolution
Old 10-02-2012, 05:06 PM   #1
Surffer227's Avatar
Functional gt scoop
I've seen multiple threads on this, and most of the arguments are it doesnt extract hot air and it makes the hood vibrate, well what if you drilled "Honda holes" on the lip on the back of the hood also? It would suck cold air in the front and push hot air out the back right? And the constant flow of air should stop the hood vibration don't you think?
Surffer227 is offline   Reply With Quote
Old 10-02-2012, 05:15 PM   #2
Venomouz831's Avatar
I would think so. I had my old 6 with a functional scoop and mines didn't vibrate though
)02 Gt, Founder of WE2G
Old 10-02-2012, 05:52 PM   #3
Surffer227's Avatar
Think its worth keeping youre engine bay cooler?
Old 10-02-2012, 06:05 PM   #4
I think the hoods with the heat louvers instead of the scoop looks cool
mymustang is offline   Reply With Quote
Old 10-02-2012, 06:06 PM   #5
Surffer227's Avatar
The holes in the back would act as heat louvers
Old 10-02-2012, 06:15 PM   #6
I don't know if it would make a drastic difference, unless you track it and I'm not meaning at the drag strip I mean like auto cross or lap T's.
Old 10-02-2012, 06:31 PM   #7
1slosix's Avatar
the problem i've seen multiple times with this is water run off right on top of the ignition coils...
carving corners like a boss
Old 10-02-2012, 06:49 PM   #8
Bamman's Avatar
I can't see it doing anything besides keeping you engine a little bit cooler, but that's not gonna make a big enough difference for it to be worth it in my opinion.
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 10-02-2012, 07:42 PM   #9
Topless04GT's Avatar
i did this about two years ago. I cut about a 14" wide, by 9" hole in the hood, removed the honeycomb, and cut 4 vents in the back of the scoop. It is not worth it. I made sure I took all the proper routes, because as many know, I do things to my car as a test dummy for people who are too nervous to do it themselves. in this instance, 90% of you would lose your scoop at freeway speeds, and you will cause more damage than good. The easiest way I explain it to people... If Ford is as big a company as they are, and they spend stupid amounts of money doing research on cars... dont you think if they wanted it functional, it would be?
this is all
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 10-02-2012, 08:28 PM   #10
Bamman's Avatar
this is all
Solid point sir.
Old 10-04-2012, 11:16 PM   #11
1slosix's Avatar
this is all
yep...if you want a heat extractor buy a hood made for it
Old 10-05-2012, 03:39 AM   #12
Butch's Avatar
Region: New Mexico
Your driving, air goes in the top through the open vents and out the bottom =} im just guessing this is how it works. To me it helps the engine blow out heat
---------- Post added at 03:39 AM ---------- Previous post was at 03:38 AM ----------
this is all
They'd probably charge extra to make it functional jaja.
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 10-05-2012, 10:31 PM   #13
1slosix's Avatar
cost of making it functional wouldn't even be noticed by the consumer...
Old 10-05-2012, 10:54 PM   #14
Butch's Avatar
Region: New Mexico
Unless your a gear head
-----NEHP---
{Never Enough HP}
Old 10-05-2012, 10:57 PM   #15
1slosix's Avatar
even then...ford changes prices year after year and even a gear head doesn't understand fully why. be that a change in material or parts. unless you tear down the car piece by piece and get a price list for every bolt you will never truely know where the cost is at.
Old 10-06-2012, 02:11 AM   #16
Butch's Avatar
Region: New Mexico
That is true I didnt think of it that way, well then they probably already charge for nonsense so what would a few more bucks be
-----NEHP---
{Never Enough HP}
10:33 AM
