Headlights vs. Parking Lights... - Mustang Evolution
Old 10-02-2012, 10:56 PM   #1
Good day all... Okay, here is my issue now that I am having. My headlights were working and my parking lights and tail lights were not unless I pushed the knob in a tad. Once I did that it all worked fine. It was suggested that I change the Headlight Switch and the Headlight Connector, both which have been done. After changing them I am still having the same issue, but this time not even pushing the knob in a tad works. Now I am pretty frustrated because the proposed fix did not work and now I think I am worse off. Any ideas people because I am all out.
Thanks!!!
devanslive is offline   Reply With Quote
Old 10-03-2012, 01:49 AM   #2
deadsp0t's Avatar
I had a similar issue after changing mine as well and it turned out the female ends of the connectors were not tight against the males.
That's unimpressive
Old 10-03-2012, 04:50 AM   #3
Are you referring to the fact that the male connectors at the back of the headlight switch are not tight enough into the connectors on the pigtail?
Old 10-03-2012, 06:45 PM   #4
deadsp0t's Avatar
Yes,
That's unimpressive
01:08 AM
