Suction sound on engine startup - Mustang Evolution
Old 10-04-2012, 05:03 PM   #1
austinknoll's Avatar
When I start the motor, I hear this suction sound every now and then. It's really weird. Vacuum leak maybe?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 10-04-2012, 05:23 PM   #2
twotone01's Avatar
All your hoses and intake tube tight?
twotone01 is offline   Reply With Quote
Old 10-04-2012, 06:01 PM   #3
Filibuster
Do you have a cai?...on cold starts I can hear mine through the vents. It may be kinda hard to hear over the exhaust, but here's a vid to see if this is anything like what you're explaining.
XXSTEVEO66 is offline   Reply With Quote
Old 10-04-2012, 06:10 PM   #4
Filibuster
I didn't notice it before I put the cai on but when it's cold with the iac valve ”choking” the engine you can really hear it..
Just a thought.
Old 10-04-2012, 08:38 PM   #5
Kingmidas87's Avatar
My CAI makes the same noise. Could still be a leak tho
Kingmidas87 is offline   Reply With Quote
Old 10-04-2012, 09:09 PM   #6
Filibuster
Could be, but a vacuum leak would affect the car much more than just a sound. If the op has performance issues as well I would suspect a leak.
Being that he said on ”start up and sometimes” hopefully it's just what we said.
We'll see what he has to say.
Old 10-05-2012, 12:02 AM   #7
V6 stang's Avatar
Mine did this once and my CAI got a gap in it letting air through.. I have to push it back in and tighten it back up
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 10-05-2012, 11:14 AM   #8
I tried searching for leaks anywhere and I can't seem to find one. Coup it be a problem with the iac? Mine was acting up a couple months ago
65 Mustang coupe
Old 10-05-2012, 03:11 PM   #9
Dgerow12's Avatar
What year is your car?
Dgerow12 is offline   Reply With Quote
Old 10-05-2012, 06:04 PM   #10
Use a can of ether or carb clean and spray around the: intake, injectors, vacuum lines, eve, etc etc etc. If the car isles up then you found the leak. Just Becareful of electrical connection.
06:59 PM
