new CAI - Mustang Evolution
Old 10-05-2012, 11:23 AM   #1
2000v6stang's Avatar
Region: Iowa
new CAI
I just put on a AM CAI and im figuring that my computer is just offsetting the extra air its bringing in is this true also im gussing i got a 5 hp boost from it if that how much would the AM stage 3 chip add to the hp from my CAI if i got it tuned for a CAI
Blacking it out, MAC duel exhaust, SR CAI, Performance Automatic shift kit. And a long build list wrecked in July '14
2000v6stang is online now   Reply With Quote
Old 10-05-2012, 02:44 PM   #2
Kingmidas87's Avatar
I personally think 5hp right now is stretching it, usually at most you'd just get better throttle response. To answer your second question, yes, a chip(or tune) from AM programmed with your CAI on there will get you gains around the 5hp. Assuming the rest of your car is in good working order and is tuned up(fresh plugs, oil, etc). Also make sure to treat you air filter at every oil change. Get a K&N recharge kit. It will have filter cleaner and filter oil. Follow the directions to get the most power and keep the most crap outta your motor.
Kingmidas87 is offline   Reply With Quote
Old 10-05-2012, 10:28 PM   #3
1slosix's Avatar
im guessing a 2ish hp gain but still every extra pony is good right. it's more of a visual mod when you pop the hood. a bit of throttle response and a couple mpg gain is usual as well. as for the chip i'd skip it and research an SCT handheld
carving corners like a boss
Old 10-06-2012, 08:39 AM   #4
Fourloko530's Avatar
I have the bama chip not bad I mean it really depends if u have the money but both of them have there pros and cons downside to the chip u have to send it in every rime u get a bolt on
Fourloko530 is offline   Reply With Quote
Old 10-10-2012, 02:55 PM   #5
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
2000v6Stang,
I see a lot of great information is being tossed around, let me try and clear things up.
A CAI on a v6 may not give you a TON of power, but it will definitely give you a power increase, throttle response, sound and some killer engine bay styling! When you pair up a CAI and a Bama Tune you'll definitely notice a big difference. The more mods you have the better the gains will be obviously!
Depending on your modification you could see a 10-15RWHP gain through out the Curve. Give my Bama team a call and they'll give you the run done on what Bama has to offer you!
Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
cai
12:07 AM
