installing a cam - Mustang Evolution
Old 10-08-2012, 04:08 PM   #1
installing a cam
Does anyone have pictures of how to install a cam on a 99-04 v6 mustang.
Blackedout is offline   Reply With Quote
Old 10-09-2012, 11:03 AM   #2
davidcseifert's Avatar
Region: Arkansas
Go to an auto parts store and pick up a Haynes or chiltons manual and it'll tell you everything you need to know, it's not "that" difficult to do really
blower/new cam soon
Old 10-09-2012, 11:16 AM   #3
Basic take off and install? Ima have to look in my Haynes magazine that I got.
Old 10-09-2012, 11:20 AM   #4
Region: Arkansas
Pretty much aside from reseting the valvetrain, certain procedure to follow to make sure they are set right but again not difficult if you understand the concept
blower/new cam soon
Old 10-09-2012, 11:20 AM   #5
wc3john's Avatar
Remove upper and lower intake along with fuel rails and injectors.
Remove radiator, fan and serpentine system.
Might have to remove the front bumper to get to it. The 3.8 is VERY similar to the 5.0 as far as installing a cam goes. Hope this helps
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-09-2012, 03:12 PM   #6
Should I just go ahead and increase the feul injectors?
Old 10-09-2012, 03:53 PM   #7
wc3john's Avatar
You'll need someone more experienced then I with v6's to answer that question but my initial GUESS would be no unless the O-rings are bad. Don't think with a cam only swap that your injectors
Old 10-09-2012, 05:27 PM   #8
Kingmidas87's Avatar
Depends on the cam. Usually the cam manufacture will tell you if you need stronger injectors. I talked about getting higher ratio roller rockers a while ago and this guy argued that a cam is better and that you don't have to remove the radiator to install one and had pictures to prove it. so that will save you time and supplies. How many miles does your stangorang have?
Kingmidas87 is offline   Reply With Quote
Old 10-09-2012, 07:22 PM   #9
126,000 mile roughly but is a completely healthy motor i oil change more often than i should 3 months. And run 93 high value feul. And keep my motor super clean.
I really need some pictures guys
Old 10-09-2012, 10:14 PM   #10
Region: Arkansas
242 SAE rwhp on factory injectors myself lol
Aren't you doing turbo with all this or some form of boost? Depending on that level of boost will tell you how big of injectors..
As for radiator it's pretty simple to remove, (bracket for overflow tank, then remove it, two top support brackets for radiator, undo upper/lower hoses with pliers, pull up to remove radiator and done) worth it to me at least for the extra working room when removing all the acces on the front of the motor.
Also, upgraded valve springs are required with any cam that is even worth the trouble swapping in.. Usually comp 915's will handle whatever you do, also hardened pushrods will most likely be needed
blower/new cam soon
Old 10-10-2012, 03:52 PM   #11
Maybe no boost. I dont wanna spend that much money on it anymore just heads/cam/intake.
Old 10-10-2012, 03:58 PM   #12
xhgwx's Avatar
David
Kyle said hardened push Rods and upgraded valve springs weren't needed with his?
xhgwx is offline   Reply With Quote
Old 10-10-2012, 04:06 PM   #13
A turbo may be too much. I would rather save it for a v8.
Old 10-10-2012, 04:13 PM   #14
Region: Arkansas
QUOTE="xhgwx"]David
Kyle said hardened push Rods and upgraded valve springs weren't needed with his?[/QUOTE]
Pushrods maybe, but better check again with valve springs bud lol
In what respect? You can do a turbo kit for a decent price, look around there is usually a good kit for sale every month or two
blower/new cam soon
Old 10-10-2012, 07:40 PM   #15
I will then. Man i would really love to turbo this car! So i plan h/c/i think they make an application for this? Like a certain cam?
Old 10-10-2012, 10:16 PM   #16
xhgwx's Avatar
Turbo kit on v6 power for 550 btw.
---------- Post added at 11:16 PM ---------- Previous post was at 11:16 PM ----------
Originally Posted by davidcseifert
QUOTE="xhgwx"]David
In what respect? You can do a turbo kit for a decent price, look around there is usually a good kit for sale every month or two[/QUOTE]
Well how much are those comp valve springs
Old 10-11-2012, 12:02 AM   #17
Region: Arkansas
Look up comp 915's, and the hardware to go with them
Yes they make cams for certain application N/A, turbo, or supercharger
You should email Kyle at
http://kylepersonperformance.m.webs.com
He can get you a quote on a Head/Cam/Intake setup for your specific goals
blower/new cam soon
06:56 AM
