6 speed v6? - Mustang Evolution
Old 10-16-2012, 04:16 PM   #1
Dogbitdude's Avatar
6 speed v6?
Is it possible to do? If so what benefits/downfalls would it produce?
Dogbitdude is offline   Reply With Quote
Old 10-16-2012, 06:54 PM   #2
Kingmidas87's Avatar
It would give you a better range. Generally cars with more gears get better fuel mileage.
Kingmidas87 is offline   Reply With Quote
Old 10-16-2012, 07:34 PM   #3
Its possible but will cost a lot and will be a huge hassle
Old 10-17-2012, 05:46 AM   #4
kickerofdoom's Avatar
Could stay in powerband longer and mpg but not really worth it unless have tons of mods
Old 10-17-2012, 07:09 AM   #5
Ford offers a 6 speed T-5. It's a T-56 I believe. Ill get more info on it. They also have HD wide and close ratio T-5's. I think you'd need to shorten the drive shaft and mod your cross member for the 6speed
Old 10-17-2012, 09:38 AM   #6
Dgerow12's Avatar
T-56 is the manual trans for an 03-04 cobra
Dgerow12 is offline   Reply With Quote
Old 10-17-2012, 09:40 AM   #7
Yep. Bolts up to a motor the same as a T-5 so just gotta do the DS
Old 10-17-2012, 10:23 AM   #8
Dogbitdude's Avatar
So basically all I would need is the right driveshaft and the t-56 tranny and I could do it?
Old 10-17-2012, 11:33 AM   #9
davidcseifert's Avatar
Region: Arkansas
No a mod motor does not have the same bolt pattern as the V6, the sixer uses a small block ford bolt pattern (aka same as 302, same reason a 4r70w or a T-45/3650 from a gt won't work on a V6)
You have to get an adapter bellhousing
blower/new cam soon
Old 10-17-2012, 07:53 PM   #10
Oh yeah, Duce I forgot. The new 5.0 prob doesn't have the same bolt pattern either, eh?
Old 10-17-2012, 07:56 PM   #11
Here is the info from my performance catalog. It's an older one, ill see if I can get a current one tomorrow
Old 10-17-2012, 11:25 PM   #12
Dogbitdude's Avatar
Where would be a good place to look for one of the cobra transmissions and what kind of price range would you suspect for the whole deal? As a reference i would be going from stock 01 v6 auto to the t-56
Old 10-17-2012, 11:33 PM   #13
Region: Arkansas
Highly doubt it would be the same DOHC 5.0 big difference lol
blower/new cam soon
02:45 AM
