fan kicking on - Mustang Evolution
Old 10-16-2012, 07:31 PM   #1
Robbiemustang96's Avatar
fan kicking on
How hot is my engine supposed to be until my fan kicks on its a 98 v6
Robbiemustang96 is offline   Reply With Quote
Old 10-16-2012, 08:49 PM   #2
jwhayne0001's Avatar
Not sure on the temp but if you turn your AC on it will blow all the time if your just wanting to see if its working
jwhayne0001 is offline   Reply With Quote
Old 10-16-2012, 09:19 PM   #3
i thought that the ac fan was different from the engine fan
Old 10-16-2012, 09:30 PM   #4
Kingmidas87's Avatar
If your vehicle has an electric fan, then it will always kick on when you turn the a/c on. If your car has a clutch(mechanical) fan then it will only spin as fast as your motor. That's why people say not to leave the a/c on if your car is in park, cuz the clutch fan at idle isn't pulling enough air thru it to cool it down. It can actually make your engine overheat, had a close call with my truck from the same thing.
There is, however, a certain degrees that the electric fan kick on. Not sure on the temp but my guess would be a little above or around 220
Kingmidas87 is offline   Reply With Quote
02:37 AM
