Upgrading brake system - Mustang Evolution
Old 10-19-2012, 10:44 PM   #1
BigT03's Avatar
I wanna swap the brakes off a Cobra to my V6 when I put on a set of 20s . What all needs to be swapped? I got stainless steel lines and just need to know what else I need.
'Arion' 2001 Mustang V6 5sp
I am Big-T, and I approve this car!
BigT03 is offline   Reply With Quote
Old 10-19-2012, 11:16 PM   #2
Fourloko530's Avatar
Why would do that to a car 20s
Fourloko530 is offline   Reply With Quote
Old 10-20-2012, 07:08 AM   #3
jdavis96gt's Avatar
Region: West Virgina
Dubs don't look right on sn95s. Atleast everyone I've seen hasn't but its your car. You need calibers, rotors, and a bracket. Check eBay that's where I seen em. But look around, you might find elsewhere cheaper.
Old 10-20-2012, 09:12 PM   #4
twotone01's Avatar
You'll need need stainless steel brake lines too
twotone01 is offline   Reply With Quote
Old 10-22-2012, 12:02 AM   #5
BigT03's Avatar
Why not? 20s make it sit better. Putting low pros on the front and bigger tires on the rear. I'm a tall guy and its hard to get in and out of a car that sits so low. I plan to put a body kit on it to make up for the height difference so it still looks low.
Old 10-22-2012, 08:45 AM   #6
davidcseifert's Avatar
Region: Arkansas
Swap out to the cobra lines, calipers, pads, and rotors, they have bigger brakes/taller rotors, I forget if the difference is made up by the caliper or if it requires a bracket to elevate the caliper some
Staggered 20's lol not as good as you'll think but to each they're own
You'll be gaining a lot of weight and making it harder to get up and go with those, lose a couple MPG's if that matters (most don't care in a mustang anyways) but at least the new brakes should counter the gain in distance to stop the car from the larger rotational mass of the wheels
blower/new cam soon
Old 10-22-2012, 08:15 PM   #7
1slosix's Avatar
18's max on a new edge..i've only seen a handful of 20's on these cars and none of them look good at all. makes them look like a cheap hot wheels car to me. but to upgrade them i'd look into an SVE brake upgrade kit from LMR
carving corners like a boss
Old 10-31-2012, 09:31 PM   #8
BigT03's Avatar
Thanks for all the ideas. If the 20s don't look right when I put them on I'll try 18s. This car wasn't made for speed lol. It's a v6. I pushed it to 117 mph(too slow). I'm goin for show and comfort. The mpg does matter but I'm working on ways to lighten the car to counter the extra weight of the rims.
Old 11-01-2012, 09:46 AM   #9
twotone01's Avatar
You'll need new brake fluid
Old 11-01-2012, 10:06 PM   #10
BigT03's Avatar
Any specific kind? Or just replace the old fluid?
Old 11-02-2012, 12:52 AM   #11
Dgerow12's Avatar
Our cars have a factory limiter on them. They top out at about 115. If you tune it they can do much better than that . You should atleast hit about 140
Dgerow12 is offline   Reply With Quote
Old 11-02-2012, 11:03 PM   #12
1slosix's Avatar
you can replace with the factory Dot 3..however if this car is gonna see real track action you can flush the whole system and start from scratch with Dot 5.1 (NOT 5.0).
but with the 20's you want i don't think this will see much action
11:50 AM
