I need help!!! PLZ!! - Mustang Evolution
Old 04-17-2008, 05:04 PM   #1
Unhappy I need help!!! PLZ!!
I have a 01 v6 Mustang... I am have a problem... Well it doesn't do it all the time but i can be driving down the hwy or just a back road and it will start being hesatent and sputting like it is not getting gas and will not accelarat when i press the gas pedal. I will have to pull over and it acts like it wants to cut off but doesn't, I can turn the car off let it sit for a sec and will be fine till it acts up again. What do i do? I also have a ticking in the engine some where but will go away after it warms up or won't be as loud...
Khstang is offline   Reply With Quote
Old 04-17-2008, 06:02 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: I need help!!! PLZ!!
when is the last time you changed the fuel filter? Air filter?
Old 04-17-2008, 06:16 PM   #3
Changed both last month
Old 04-17-2008, 06:17 PM   #4
Region: Iowa
plugs?
Old 04-17-2008, 06:22 PM   #5
Had the 100,000 mile tune up done and everthing
Old 04-17-2008, 06:28 PM   #6
Region: Iowa
how far past that are you?
Old 04-17-2008, 06:30 PM   #7
Region: Iowa
ever cleaned your MAF? That could be dirty, which could cause inaccurate air flow readings. Are you throwing any check engine lights?
Old 04-17-2008, 06:45 PM   #8
My MAF what is that? so yeah no never have cleaned it and no not getting any check enine lights
Old 04-17-2008, 06:50 PM   #9
Region: Iowa
there's a sensor determining how much air is coming into your engine (Mass Air Flow). If that gets dirty, it can vary the reading randomly. It's in your intake tube. You'll need residue free electrical contact cleaner to get it done right. Other's may have other suggestions. But, this couldn't hurt. You may consider seafoaming the car too. It works wonders for cleaning out engines and fuel lines.
Old 04-17-2008, 07:02 PM   #10
so how would i go about doing all that and the cheapest way i can i am car retarded
Old 04-17-2008, 07:14 PM   #11
Region: Iowa
get a can of electrical cleaner. Take off intake, spray sensor... reinstall intake. Probably disconnect battery for a couple minutes
Old 04-17-2008, 07:16 PM   #12
Is there some where i can look up to tell me... Where the intake sensor is so i don't screw something up
Old 04-17-2008, 07:23 PM   #13
Region: Iowa
it's the sensor that sticks into the middle of the intake tube.
Old 04-17-2008, 07:24 PM   #14
ok .. and the sea foam just any auto parts store
Old 04-17-2008, 07:29 PM   #15
Region: Iowa
yes
Old 04-17-2008, 07:31 PM   #16
all right i will try that thanks
Old 04-19-2008, 07:23 AM   #17
Also...I had a problem that sounds very similar to what you are experiencing...ended up replacing my frps (fuel rail pressure sensor) and my fuel pump and hat and fixed the problem...
Old 04-19-2008, 12:25 PM   #18
How much did that run you?
Old 04-21-2008, 10:33 PM   #19
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
i estimate it at 300-350 for PR, FP, and hat.
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
need some help plz. j4gwig General Mustang Discussion 2 05-10-2010 05:29 PM
plz welcome me Qatari Mustang New Member Introductions & Greetings 10 09-24-2009 09:20 AM
estimate plz upton7 General Mustang Discussion 4 04-03-2009 02:36 PM
Need some help plz! graveelement Pre-2005 V6 Mustang 0 02-09-2008 03:15 PM
plz need info 95gt350 1979-1995 Mustang GT 2 12-18-2005 10:58 AM
03:13 PM
