injectors not opening im new please help! - Mustang Evolution
Old 10-23-2012, 07:05 PM   #1
96 3.8 base... My injectors are not functioning at all. I'm getting fuel pressure all the way up to the rail, but the injectors are not allowing fuel through. Please someone give advice I'm new to this forum it's my last resort my car has been out of commission for about a month, thank you.
mikedeck is offline   Reply With Quote
Old 10-24-2012, 12:07 AM   #2
1slosix's Avatar
are they just clogged and sputtering or no fuel at all? you can either A. suck Seafoam straight into that upper with the vaccum line off the brake booster (not too much at once) B. pull the injectors put them in a bowl and fill the bowl with seafoam..let them sit overnight
carving corners like a boss
Old 10-24-2012, 12:39 AM   #3
Lorraine's driver
ab_mach1's Avatar
Here's a link on how to test your injectors...
How to Test the Fuel Injectors
(Ford 3.0L, 3.8L)
Here's a link on how to clean your injectors...
Home Made Injector Cleaner
Instagram: @ab_mach1
Old 10-24-2012, 08:42 AM   #4
I guess i should have been more specific, i already tried replacing the injectors so i know its not the injectors themselves. it has to be something electronic controling the injectors. I've checked all the fuses. as far as i know there is no relay specifically for the injectors on the 96.
---------- Post added at 09:42 AM ---------- Previous post was at 09:40 AM ----------
By the way thank you for your time guys.
Old 10-24-2012, 11:49 AM   #5
Lorraine's driver
ab_mach1's Avatar
So, you have pressure at the rails. You have new injectors, but they are not operating. And you are getting a trouble code? I'm just curious if there is something else that is malfunctioning that is causing this to happen. We don't want to replace something that is working fine. Have you performed any tests that would confirm you are getting power to the injectors?
Old 10-24-2012, 05:27 PM   #6
Just checked, no power getting to injectors, damnn itttt
Old 10-24-2012, 06:40 PM   #7
Lorraine's driver
ab_mach1's Avatar
Sorry, that sucks. Did you test with a noid light? The light will flash when voltage is present. If your not getting voltage, maybe your wire harness is damaged somewhere. Could be something wrong with the PCM. Maybe the crank sensor or cam sensor are malfunctioning and making it so the PCM is not calling for fuel from the injectors.
Old 10-24-2012, 07:18 PM   #8
im having trouble locating the crankshaft sensor, any clue where its at? Thanks again for the help.
Old 10-24-2012, 07:39 PM   #9
Lorraine's driver
ab_mach1's Avatar
Here's a pic from my Chiltons. Hope that helps
Old 10-26-2012, 04:48 PM   #10
Tested crank shaft sensor and its workin perfectly
Old 10-27-2012, 02:09 PM   #11
Thank you for your time everyone, i took it to my mechanic today I just don't have the time to chase electrical problems right now wish me luck though haha
Old 10-27-2012, 04:12 PM   #12
Lorraine's driver
ab_mach1's Avatar
Cool, totally understand that. Gook luck. I hope it's something simple where we can all go "ah, I shoulda thought of that".
Old 10-29-2012, 11:18 AM   #13
Yeaa ill defiantly let u know what it was thanks again
CAI and 31 LB injectors southernstang00 Mustang Parts for Sale and Wanted 10 10-27-2012 01:30 PM
Fuel injectors? WhiteCobra94 1979-1995 Mustang GT 12 01-05-2012 07:03 PM
injectors Robbie94gt 1979-1995 Mustang GT 18 11-21-2011 07:30 PM
Fuel injectors ?? stangstar92 1996-2004 Mustang GT 3 10-05-2011 04:59 PM
60 lb injectors question? CZYFAST 2011-2014 Mustang GT 27 07-19-2011 02:56 PM
04:13 PM
