Head gasket - Mustang Evolution
Old 10-23-2012, 09:46 PM   #1
Anthony8994's Avatar
Head gasket
My head gasket blew I have some mechanical knowledge but I am no expert do u think I can do it myself put should I not even try????
Anthony8994 is offline   Reply With Quote
Old 10-23-2012, 10:19 PM   #2
watson 1025's Avatar
I've done it before and what helps is I make sure I keep all the bolts organized so I know exactly where they go, and after each step I take a pic so I know how it goes back together. Just make sure you have the torque specs so you know what to torque everything down to. Haynes and chiltons has em.
watson 1025 is offline   Reply With Quote
Old 10-23-2012, 10:22 PM   #3
Yea if you read through a haynes and feel comfortable enough after reading to give it a shot. It's not the hardest thing to do but it's not swapping out an alternator either expect at least a full day of work for your first time out take your time read the manual and you should be just fine. I advise you change both as the for the fact that you have the engine apart and its good practice to change them in pairs for the simple reason that the other side might blow and you have to tear into it again. You'll also need a new upper intake gasket , exhaust manifold gaskets and you dont have to if there not leaking but regardless of condition i would get new valve cover gaskets too.
l2plagears is offline   Reply With Quote
Old 10-24-2012, 01:57 AM   #4
davidcseifert's Avatar
Region: Arkansas
The exhaust gaskets are reusable on our sixers, they're mls metal gaskets and seal wonderfully
blower/new cam soon
Old 10-24-2012, 07:23 AM   #5
Good to know bro i had no idea those are reusable. Does that apply to any metal spring loaded gasket?
Old 10-24-2012, 10:56 AM   #6
Region: Arkansas
Not sure what other gaskets are (besides heads that are mls, and no can't be reused lol)
blower/new cam soon
Old 10-24-2012, 11:21 AM   #7
The sad part is i'm sure someone has tried............... ever see that vid of the dude changing a head gasket and straight up puts the head back on w/o the gasket , hilarious!
04:48 AM
