american muscles new valve body - Mustang Evolution
Old 10-31-2012, 01:21 PM   #1
SN95V600's Avatar
why does it say 01-04 v6 not 99-04? i wana replace that on my tranny
SN95V600 is offline   Reply With Quote
Old 10-31-2012, 03:30 PM   #2
03torch's Avatar
They switched the transmissions halfway through 2001 look on your door code to see what transmission you have the late 01-04 is tr3650 I'm pretty sure may have a number switched but the 99-01 is a way different code
03torch is offline   Reply With Quote
Old 11-01-2012, 01:50 PM   #3
SN95V600's Avatar
Are you sure both base and v6 had 4r70w for autos and manuals had base was a t5 and gts had t45
Old 11-01-2012, 01:51 PM   #4
SN95V600's Avatar
Old 11-01-2012, 02:32 PM   #5
03torch's Avatar
I'm not sure the easiest way for you to check would be go on your door jam on the drivers side and it should let you know what transmission you have
Old 11-01-2012, 03:31 PM   #6
SN95V600's Avatar
Im gana have to check the tag on the tranny cuz i replaced already so its not original
Old 11-01-2012, 03:43 PM   #7
SN95V600's Avatar
Its frm a 99 for sure but ehhh idk i might go stick
Old 11-01-2012, 09:32 PM   #8
Dgerow12's Avatar
If your car is a auto then it is a 4r70w as long as its in the 99-04 year range
Dgerow12 is offline   Reply With Quote
Old 11-02-2012, 07:35 AM   #9
SN95V600's Avatar
Im just curious why it says things like that 01-04 it confuses
Old 11-02-2012, 12:30 PM   #10
Dgerow12's Avatar
Post me a link so I can look at it
Old 11-02-2012, 12:36 PM   #11
Dgerow12's Avatar
Go to 99-04 tab on AM and search valve body they also offer one for the 96-00 gt and v6 that is cheaper than the 01-04 valve body
Old 11-02-2012, 04:45 PM   #12
SN95V600's Avatar
Yea i know but i hate that **** though even though its like the same tranny for all yrs
Old 11-02-2012, 07:35 PM   #13
Dgerow12's Avatar
There's prolly a difference in the valves and shift pressures
Old 11-03-2012, 12:38 AM   #14
1slosix's Avatar
yeah my '04 GT had a tr3650...sucked when the 3rd gear syncro when out...turned out to be a common issue after doing research online
carving corners like a boss
Old 11-03-2012, 05:32 AM   #15
SN95V600's Avatar
Thanks for the help guys
05:30 PM
