I Dont Get THis Problem? - Mustang Evolution
Old 04-24-2008, 12:29 PM   #1
Question I Dont Get THis Problem?
I HAVE A 96 3.8 V6 MUSTANG AND MY QUESTION WAS EVERY TIME THAT IM COMING TO A COMPLETE STOP I NOTICE THAT THE RPMS DROP BELOW FIVE HUNDRED, AND THE THE CAR SHAKES AS IF THE ENGINE TRYIES TO DIE I GUESS. IT RUNS PERFECTLY, IDLES FINE AND BRAKES NORMALLY. I CHECKED EVERYTHING OUT AND I COULDNT FIND ANYTHING WRONG WITH IT. SO IF ANYBODY HAS HAD THIS PROBLEM OR MAY KNOW SOMETHING ABOUT IT THAT CAN PLEASE HELP ME OUT, PLEASE DONT HESITATE TO WRITE BACK
stang_619 is offline   Reply With Quote
Old 04-24-2008, 12:36 PM   #2
Send a message via AIM to rwboring
Re: I Dont Get THis Problem?
what did you check? it could be anything from a fuel filter to bad gas to MAF...
rwboring is offline   Reply With Quote
Old 04-24-2008, 12:37 PM   #3
1234's Avatar
not to mention just about every sensor on the motor
Old 04-24-2008, 12:39 PM   #4
auto or man?
Old 04-24-2008, 01:24 PM   #5
I'd check the MAF first and clean this.
Old 04-24-2008, 01:58 PM   #6
clean the maf really good wtih electronic cleaner NO residue on contact cleaner.
then you can check the idle bypass valve (iac) on the upper intake, its near the throttle body and cylinder shaped.
Old 04-25-2008, 08:08 AM   #7
Herbstang's Avatar
Fuel Filter ??
Old 04-25-2008, 08:34 AM   #8
is that a why did i say it?
Old 04-25-2008, 09:51 AM   #9
wiarumas's Avatar
everything that everyone said so far... could also be a bad spark plug maybe...
Old 04-25-2008, 09:53 AM   #10
Herbstang's Avatar
No that's a maybe it's a filter
Old 05-02-2008, 10:41 AM   #11
could also be a sticking idle valve you can take it off and clean it and see if it helps
jedwards242000 is offline   Reply With Quote
just dont know what to do zapstang Pre-2005 V6 Mustang 5 07-06-2009 07:16 AM
i just dont get it Dark02Pony The Bar 11 01-06-2006 07:02 PM
Dont get Slapped.. Falcon The Bar 4 03-27-2004 12:54 AM
09:07 PM
