2008 Mustang GT stock exhaust on a 2004 V6 - Mustang Evolution
Old 11-04-2012, 07:45 AM   #1
Crowned1's Avatar
I've brought this up before in a thread and haven't gotten a clear response so does anyone know if it's possible? Would it sound good? Should I switch the mufflers? Would i need any new piping? Cost? Sorry i have a lot of questions i'm a noobie.
Crowned1 is offline   Reply With Quote
Old 11-04-2012, 05:07 PM   #2
03Sixtang's Avatar
Region: Nevada
You can do it, I don't know what it would sound like. To do it by yourself you are going to haw to by the H pipe v6 adapter from AM. It does require a little bit of cutting but the rest is bolt on
03Sixtang is offline   Reply With Quote
Old 11-04-2012, 11:04 PM   #3
lemons95's Avatar
I think 2005 and up mustang's use an axle-back exhaust system. which means you'll probably need more piping since are mustangs use a cat-back system.
If you already have the exhaust from the GT or can get it for a good deal I'd say go for it.
Old 11-04-2012, 11:30 PM   #4
03Sixtang's Avatar
Region: Nevada
Oh yeah I didn't realize you were talking about an 08 gt exhaust, in that matter, you will most likely need custom tubing
Old 11-05-2012, 12:11 AM   #5
Crowned1's Avatar
you are correct they are axel backs, my friend is willing to give me his stock exhaust because he has a pypes exhaust system on his 08 so he has no use for it really but i guess i could just go to an exhaust shop and go from there huh? Do you think it would sound good?
Old 11-05-2012, 12:33 AM   #6
JetLife 01GT's Avatar
It's hard to say what it will sound like. If you can get them for free from your friend it's worth a shot I think. And with that exhaust you'll now have 2 exhaust tips coming out the back. I'd swing by an exhaust shop and see if they can do it. They'll probably just hack off the mufflers and they'll have to do custom tubing to make them work.
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-05-2012, 12:36 AM   #7
Crowned1's Avatar
i mean it will sound better than the stock single pipe haha. and it shouldnt be to expensive. im only doing it cause i dont want to put to much into the car as i will only have it for another 2 years. do you think there would be any performance gains?
Old 11-05-2012, 12:44 AM   #8
Idk. Idk how an exhaust affects sixxers. I would think so tho. Especially if you use piping bigger than stock. Won't be very much of a gain but you should pick up something. Anything to let your engine breathe better will. I picked up a slight bit of low end torque when I put on my cat back. Maybe consider having the shop divorce your pipes and have them fab you up a catless mid pipe. Just a thought lol
2001 GT
Old 11-05-2012, 10:59 AM   #9
Crowned1's Avatar
instead of buying an h pipe? what would be the result of having a catless mid pipe?? haha sorry im a noob!
Old 11-05-2012, 11:35 AM   #10
Dgerow12's Avatar
This is a diagram of exhaust setups. Catless will add a bit of raspy ness and a lot louder
Dgerow12 is offline   Reply With Quote
Old 11-05-2012, 02:52 PM   #11
Catless, it will be louder and help things flow better. But if you gotta pass emissions get some high flow cats. Unless you don't mind swapping ur mid pipe out each time you go to smog ur car
2001 GT
Old 11-05-2012, 03:27 PM   #12
lemons95's Avatar
I live in california, but we only have to smog the vehicle when we sell it or bring it off of non-op. I don't know what it's like where your at but if your going to sell it in a couple years you should keep the cats. Just to avoid any hassle.
Old 11-05-2012, 03:51 PM   #13
05+ on pre 05 wont work very good if at all, pass on it
Old 11-05-2012, 04:56 PM   #14
You have to smog every two years in California.
2001 GT
Old 11-05-2012, 10:48 PM   #15
Crowned1's Avatar
i live in texas
Old 11-06-2012, 12:13 AM   #16
lemons95's Avatar
Not where i'm at. In humboldt it's rural area or something so we don't have to.
Old 11-06-2012, 09:06 AM   #17
Crowned1's Avatar
why wouldn't it work?
Old 11-06-2012, 09:51 AM   #18
the 94-04 design places the mufflers in front of the rear axle and the pipe directions and bends are different than 05+
The 2005+ places the mufflers at the back bumper vs under the car as previous years.
You have no room behind the rear bumper for those mufflers.
Old 11-06-2012, 10:42 AM   #19
Crowned1's Avatar
But i mean they have to make custom piping either way so they could just make the piping shorter no? I'll have to just take it to a shop and see. There is a shop here that strictly works on mustangs so they'll tell me!
Old 11-06-2012, 12:26 PM   #20
for my 2001 V6 I had all of it custom bent/made from the Y pipe back (cut off the Y pipe ran true duals also on a 3.8L even fire motor there is no need for a balancer pipe (aka h pipe))
the mufflers wont fit on the back of the car, at least not without hanging very low and looking bad. YOu cant tuck them under the car unless you really mess them up as the tips are on the end of them.
Get a quote for custom bent 2.25 pipe (stainless steel only) from Y pipe back with what ever muffler you want in the OEM location.
Old 11-06-2012, 01:04 PM   #21
Crowned1's Avatar
so basically i could just change the mufflers? and then have no balance pipe if i wanted to?
Old 11-06-2012, 10:55 PM   #22
lemons95's Avatar
an H-pipe would make it a little bit deeper sounding.
and SpectorV I've already said that the 05 up mustangs use axel-back exhaust.
Old 11-07-2012, 03:59 PM   #23
Crowned1's Avatar
i hope it works!
2008 mustang, exhaust
10:28 PM
