fo. V6 Fog Lights - Mustang Evolution
Old 11-07-2012, 02:33 PM   #1
V6in's Avatar
fo. V6 Fog Lights
Ok so I just bought the OEM switch for the fogs and the lights w/ brackets. What else do I need and how do I wire them up ?
V6in is offline   Reply With Quote
Old 11-07-2012, 05:05 PM   #2
1slosix's Avatar
did you get a wiring harness with the switch or just a switch?
carving corners like a boss
Old 11-07-2012, 06:04 PM   #3
V6in's Avatar
Just the switch... And I just put it in and it has power and everything.
Old 11-07-2012, 06:43 PM   #4
Dgerow12's Avatar
I want to get the switch for when I get my fogs
Dgerow12 is offline   Reply With Quote
Old 11-07-2012, 07:32 PM   #5
1slosix's Avatar
you'll also need the fog light wiring harness for the oem switch. the harness will connect to the wiring that powers the switch
Old 11-07-2012, 09:04 PM   #6
Dgerow12's Avatar
Well what's your opinion slo. Should I get the oem switch or should I wire it to my ambers? I have halos now but I will be replacing them with black housed clear oem heads
Old 11-07-2012, 09:41 PM   #7
1slosix's Avatar
i have the oem switch but found it was cheaper to wire to my ambers over buying the harness lol
Old 11-07-2012, 09:43 PM   #8
Dgerow12's Avatar
Is it possible to do both? So I can run just my fogs or have them turn on when I turn on my headlights?
Old 11-07-2012, 09:44 PM   #9
V6in's Avatar
By wire harness do you mean the wires that plug into the actual switch ? Bc I just took out the one that's there (the black original one) and put the new one in its place and put those wires in it... It turns on and off and lights up.
Old 11-07-2012, 09:46 PM   #10
1slosix's Avatar
if you run to your amber you can do that...one pull on the headlight switch to kick on the fogs and ambers...two pulls to turn them on with the headlights
im referring to the harness that goes from the fog bulbs to the wiring that connects to the switch.
Old 11-07-2012, 09:48 PM   #11
Dgerow12's Avatar
Also is there a special kit that I have to get to make the fogs HIDs?
Old 11-07-2012, 10:34 PM   #12
1slosix's Avatar
no just an HID kit with the bulb type for your fogs (880)
Old 11-07-2012, 11:18 PM   #13
brooksyx's Avatar
Hey not trying to hijack your thread but i would also like to put some fog lights in my v6 and wire them to the ambers.
If I were to buy these plus some wire. Would I need anything else to mount them or will just some standard screws be just fine? Also what would be the best and cheapest way to wire to the actual light terminal?
99 04 Ford Mustang Cobra Fog Lights Smoke Lens OE Style Bulbs Foglights Set | eBay
brooksyx is offline   Reply With Quote
Old 11-07-2012, 11:30 PM   #14
Dgerow12's Avatar
Cobra fog light will only fit a cobra bumper. You will need gt fogs and you will need to cut the plastic grate that is on the v6 bumpers from the factory for where the fogs go
---------- Post added at 02:30 AM ---------- Previous post was at 02:29 AM ----------
Actually nix that they look like gt lights. Just make sure they will fit a 99-04 gt and your good with those
Old 11-07-2012, 11:36 PM   #15
brooksyx's Avatar
Yeah I dont know why it says cobra. But it was just an example.
So yeah cutting out the grate is the first part but as for installing them is it just screws? And for the plug is that something autozone or o reillys would sell? Is there a cheaper way to wire it up? Also if I wire them to the ambers I assume they will flash with the turn signal?
Trying to mod my mustang on a cheap budget ha. Thanks
Old 11-07-2012, 11:44 PM   #16
Dgerow12's Avatar
Actually that is an excellent question. Slo would know more than me. I don't have my fogs on yet
Old 11-08-2012, 06:27 AM   #17
1slosix's Avatar
There are two power wires on the ambers...the constant power and flasher wire. If you wire your fog power to the constant power wire youll be fine. It wont flash that way. Also yes you will just screw the fogs in. Your v6 bumper already has the three holes needed to install fogs. Id take the bumper off for the install btw..just easier then leaving it on
Old 11-08-2012, 11:03 AM   #18
brooksyx's Avatar
Looks like these pig tails should work with most of the fog lights out there. And at less than $5 why not?
http://item.mobileweb.ebay.com/viewi...id=54921563316
Old 11-08-2012, 02:33 PM   #19
1slosix's Avatar
you can also get those at most auto parts stores
Old 11-08-2012, 02:45 PM   #20
brooksyx's Avatar
Yeah I just went ahead and purchased those. Will take a while to get here but that's alright not in a huge hurry. Got some other mods I am working on right now.
11:14 PM
