Realistic Expectations - Mustang Evolution
Old 11-13-2003, 11:57 AM   #1
Hey, someone shoot straight and give me CONSERVATIVE, realistic expectations for rwhp & rwtq on my project. I don't want to be dissappointed, so shoot low.
8 psi Vortech non-intercooled
1. [Estimate Numbers]
12 psi Vortech non-intercooled
2. [Estimate Numbers]
FYI...
Vortech V2
80mm lightning MAF
255lph fuel pump
42# Injectors
Fordchip
oh, and the Aluminum driveshaft (+2 rwhp baby! W00T!
MaestroSC is offline   Reply With Quote
Old 11-13-2003, 10:52 PM   #2
on a 99+ correct?
1) 260-270
2) 290??
? I dont really know anyone with a vortech so I cant compare. I know with a 11psi procharger on a stock motor my friend made 278... so Im basing it off that.
dont forget youll need your stock crank pulley.
edit: just realised your 5spd.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-13-2003, 10:55 PM   #3
Monkey's Avatar
like i said on 3.8.
8psi, you'll see 250rwhp max when not IC'd
12psi you should see about 290 like stangin99 said.
Old 11-14-2003, 06:09 AM   #4
Danger Dude's Avatar
In looking at the actual HP gains I am amazed at the differences in the gains between to very similar cars. I have learned that it hard to determine the actual gain on a specific car!!! In the Ballpark is about as close as gets with dyno guessing!!!!
Old 11-14-2003, 07:27 AM   #5
True Mr. Corey. Just looking to get a conservative ballpark figure.
Still leaning towards the 12 non-intercooled setup. Add and "aftercooler" (essentially water-to-air intercooler) later.
Old 11-14-2003, 09:43 AM   #6
tire's Avatar
Send a message via AIM to tire
those guys are on track, i agree with them.
tire is offline   Reply With Quote
Old 11-14-2003, 10:07 AM   #7
I concur with the numbers stangin99 and Monkey saidI would hope with the 8 psi you would see a litttle more than 250rwhp but then again it is in the ballpark
Old 11-14-2003, 10:14 AM   #8
RGR
Send a message via AIM to RGR
Re: Realistic Expectations
FYI...
Vortech V2
80mm lightning MAF
255lph fuel pump
42# Injectors
Fordchip
If you have a dyno on the baseline, we can all make a better guess.
I'm saying +60 (8#) and +90 (12#) for the HP ratings.
It could be as high as +65 and +100 maybe...
I agree with the consensus.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 11-14-2003, 10:25 AM   #9
Excellent. Thanks everybody for your responses!
Old 11-14-2003, 10:44 AM   #10
RGR
did U ever get a baseline yet?
I see that U say +2 RWHP for a driveshaft...
Old 11-14-2003, 11:08 AM   #11
LOL! You took me literally. I was being sarcastic, I have NO idea what the actually rwhp gains of the driveshaft was, I just know it wasn't much at all-thus the 2 rwhp comment. I've heard anywhere from 2-5 rwhp.
Not really wanting to spend the money on getting a dyno run to establish my baseline. I wish it was more affordable and I would . It would be nice to have a before/after reference.
Old 11-14-2003, 11:26 AM   #12
RGR
OK, kewl.
250 RW might be a bit high, you are at probably 170 RW now so expect at least 230 RW. IMO
Old 11-14-2003, 11:38 AM   #13
I was thinking I had ~170ish right now too and was adding it up.
This all leans me to go 12psi. 230rw is just not very impressive.
Oh if I could afford the "Aftercooler"!
Old 12-21-2003, 06:50 PM   #14
Falcon's Avatar
Send a message via AIM to Falcon Send a message via MSN to Falcon Send a message via Yahoo to Falcon
yea what corey said
-Derek
1999 Trans Am WS6
Full Stainless Magnaflow Exhaust, Stainless Longtubes/Off Road Y-Pipe, QTP E-Cutout, HP Tuners, Super Sucker Ram Air Kit, BMR Tunnel Brace/Driveshaft Safety Loop, Hotchkis Panhard Bar, Hypertech 160 Thermostat, CF Whisper Air Lid, Corvette FRCs, K&N, !AIR, !EGR
Falcon is offline   Reply With Quote
Realistic power increase in 2009? SpectorV 2011-2014 Mustang GT 28 08-23-2008 10:11 AM
Realistic Engine Expectations of the 2009 Ford Mustang... RGR 2011-2014 Mustang GT 16 08-05-2006 07:35 PM
Need some advice on some realistic numbers from enginebasics ASSEMbler Pre-2005 V6 Mustang 25 11-14-2003 01:44 PM
11:25 PM
