Speedo gear - Mustang Evolution
Old 11-12-2012, 10:16 PM   #1
Surffer227's Avatar
Speedo gear
I herd ford sells different color speed sensor gears to fix your speedometer being off, I have 3.73s and 18 inch rims, anyone know what color I need?
Surffer227 is offline   Reply With Quote
Old 11-12-2012, 11:22 PM   #2
davidcseifert's Avatar
Region: Arkansas
Isn't your car a new edge? (99-04) they just require computer modification, and rim size doesn't matter as long as you have the proper size tire on it, what is the tire size?
blower/new cam soon
Old 11-13-2012, 06:21 AM   #3
Surffer227's Avatar
I thought our cars had speedo gears??
Old 11-13-2012, 07:07 AM   #4
Dgerow12's Avatar
Nope. 99-04 is. Electronically calibrated
Dgerow12 is offline   Reply With Quote
Old 11-13-2012, 07:08 AM   #5
Surffer227's Avatar
So i need to buy A tuner?
Old 11-13-2012, 07:12 AM   #6
V6in's Avatar
Are gears hard to install yourself ?
V6in is offline   Reply With Quote
Old 11-13-2012, 08:57 AM   #7
Surffer227's Avatar
If you have the mechanical knowledge not realy
Old 11-13-2012, 10:11 AM   #8
you have two choices
a speed cal unit (plugs in between trans and VSS sensor to modify the signal) or a tune. Make sure your year/trans etc is compatable with the speed cal unit or get a tune to fix it.
rims have no effect, its the tires. If they maintain the stock overall height no change is needed.
11:45 PM
