8.8 Gears - Mustang Evolution
Old 11-13-2012, 09:48 PM   #1
V6in's Avatar
8.8 Gears
What are these and what will they do? Bc I was gonna get 3.73 gears for my car
V6in is offline   Reply With Quote
Old 11-13-2012, 09:49 PM   #2
Venomouz831's Avatar
You mean 8.8 read end?
)02 Gt, Founder of WE2G
Old 11-13-2012, 09:51 PM   #3
davidcseifert's Avatar
Region: Arkansas
if you have an 8.8 rear end from a gt then they can work..
blower/new cam soon
Old 11-13-2012, 09:57 PM   #4
V6in's Avatar
Sorry I didn't post this picture its from Craigslist
Old 11-13-2012, 09:59 PM   #5
Region: Arkansas
well you have to pull a gt rear end and swap into your car to use them, and then even at that those are 3.27 gears which is the same ratio that's in your car right now
blower/new cam soon
Old 11-13-2012, 10:00 PM   #6
You would just be upgrading to a stronger rear end
Old 11-13-2012, 10:02 PM   #7
V6in's Avatar
Ok, do you guys think I should go with 3.73 gears or 4.10?
Old 11-13-2012, 10:03 PM   #8
You auto or manual? I went with 4.10 since I tracked my car at the strip and auto x
Old 11-13-2012, 10:03 PM   #9
Region: Arkansas
3.73's if you do a decent bit of highway mileage
blower/new cam soon
Old 11-13-2012, 10:06 PM   #10
V6in's Avatar
It's an automatic.
Old 11-13-2012, 10:15 PM   #11
Mine was auto that's what I would reccomend
Old 11-14-2012, 10:26 AM   #12
Harper's Avatar
you should be able to determine the gear ratio of your current rearend one of three ways:
1. door tag
2. rear end tag (should say something like 3.L27 if its currently 3:27 gears, if its 3.L55 (3:55's). 3.L73 (3:73's) and so on and so forth. the L indicates locking differential
3. jack up the rear of your car and rotate the tire/wheel one full round and see how many times your drive shaft rotates...you can make a "white out" mark on both to determine how many revolutions.
with an automatic most prefer 3:73's on a daily driver other more aggressive drivers prefer 4:10's.
hope this helps...
2003 COBRA/2004 GT w DOHC Cobra Engine and trans/5spd. IN PROGRESS
67 Mustang Coupe.
1965 F100 w/EFI 5.0 w 5spd.
Harper is offline   Reply With Quote
05:44 AM
