Eibach or H&R for the sixxer? - Mustang Evolution
Old 11-16-2012, 05:59 PM   #1
austinknoll's Avatar
I'm trying to decide on whether to get the eibach springs designed for the V6 (1.5in all around) or HR springs that lower the GT about 1.7 front and 1.6 rear? What will lower the most? Or should I cut the stock springs? What is the danger of cutting springs? Please post your ride and how much it lowere Thanks a lot guys!
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 11-16-2012, 07:59 PM   #2
Blown6's Avatar
Region: Iowa
Cheapest option is to cut the stock springs with a grinder and a cutoff wheel.
The quality between the two is about the same, But I'd go with H&R for the sole fact that its drops you low.
Another cheap option is to go with Latemodel Resto's Lowering springs. If you leave off the Iso's and just wrap the ends in electrical tape (This lasts for at least 5 years, despite what the naysayers will tell you) and it will drop you about 1.8-1.9"
Blown6 is offline   Reply With Quote
Old 11-16-2012, 08:57 PM   #3
Siendly22's Avatar
H&R Super sports ! FTW
Siendly22 is offline   Reply With Quote
Old 11-16-2012, 09:53 PM   #4
1slosix's Avatar
stay away from GT rated springs..you don't have the body weight to get even the drop they get from a certain set of springs.
as for the gentleman that mentioned cutting...its a decent option if you have a free day
here's what 1.25 coils off the front and 1 coil off the back looks like (no iso's)
guess i'm pulling my wing back off tomorrow...this old pic made me realize why i took it off the first time lol. why'd i ever put it back on
carving corners like a boss
Old 11-16-2012, 10:26 PM   #5
Yeah I'm confused as of how much the HRs will lower it. I know it's not gonna be what it says on AM. I've heard bad stories about people cutting the springs
65 Mustang coupe
Old 11-16-2012, 10:36 PM   #6
Siendly22's Avatar
1.75 front 1.6 rear those are with spring iso's
Old 11-16-2012, 10:39 PM   #7
Siendly22's Avatar
Here's another picture with H&R and adjustable KYB shocks and struts , with x2 balljoint and steeda bumpster kit with mm c&c plates
Old 11-16-2012, 10:43 PM   #8
1slosix's Avatar
those bad stories involve people that use a torch to cut their springs...or lop off over 2 1/2 coils not knowing they're about to have a good time lol. If i could ever find the time to get a free day that i don't have a honey-do list i'm gonna cut my current cars springs and do a proper write up.
Old 11-17-2012, 02:53 AM   #9
Here is a link for picturs of any combination of lowering springs installed on our Mustangs.
FYI- Ford Racing "F" springs are spec'ed for the V6 also.
Lowering Spring Picture Database (add your pic)
Old 11-17-2012, 02:53 AM   #10
Yeah but you also have struts too.
65 Mustang coupe
Old 11-17-2012, 11:31 AM   #11
1slosix's Avatar
we only have shocks....that's being said his pic should still be 99% accurate for your needs
Old 11-17-2012, 01:27 PM   #12
So shocks don't make a difference in ride height? I know going lower on stock shocks puts more stress on them.
65 Mustang coupe
Old 11-17-2012, 02:21 PM   #13
1slosix's Avatar
it's just because stock shocks aren't made to smooth out a ride with so little dead space between the tire and wheel well.
06:37 AM
