Whistle Under the Hood - Mustang Evolution
Old 11-18-2012, 07:49 AM   #1
Ghostedmind's Avatar
Alright, so i have this whistling under the hood, sounds like it could be a vacuum leak or an intake leak maybe. I was wondering if anyone knew of a common problem area for this. It sounds like its comming from around the EGR area (at least thats where it sounds the loudest to me) and if it is an intake leak (between the intake and EGR, or between the upper and lower intake) can someone give me some ideas on a good way to repair it
Thanks guys
LCMC Member
Old 11-18-2012, 08:29 AM   #2
Adogg's Avatar
[QUOTE="Ghostedmind"]Alright, so i have this whistling under the hood, sounds like it could be a vacuum leak or an intake leak maybe. I was wondering if anyone knew of a common problem area for this. It sounds like its comming from around the EGR area (at least thats where it sounds the loudest to me) and if it is an intake leak (between the intake and EGR, or between the upper and lower intake) can someone give me some ideas on a good way to repair it
Thanks guys[/QUOTE
Is this an after market intake if so then some of them have a natural whistle if it is not then I would take it of and put it back on extra tight
Don't hate....... appreciate
Old 11-18-2012, 01:22 PM   #3
I have a K&N intake but thats not where the whistle is comming from, this is a new sound that hasn't been there before (K&N has been on the car since i bought it a year ago) other than that the upper and lower intake is stock.
LCMC Member
Old 11-18-2012, 02:40 PM   #4
bmabbott's Avatar
With the car running... spray some gumout (or any carb cleaner) around the intake... if the car's idle revs a bit, then you found where your vacuum leak is... spray around all your intake hoses, gaskets... etc
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 11-18-2012, 08:17 PM   #5
Ok, so i tried this, and nothing. Is there anything else that someone knows coud cause this sound? water pump maybe? its the loudest right around the EGR valve
LCMC Member
Old 11-18-2012, 08:32 PM   #6
03Sixtang's Avatar
Region: Nevada
You could try some new egr valve gaskets
03Sixtang is offline   Reply With Quote
Old 11-18-2012, 10:04 PM   #7
1slosix's Avatar
yeah could just be a shot egr gasket...go grab you a new one and swap it out...a couple bucks to at least see if it's the issue
carving corners like a boss
Old 12-02-2012, 12:55 AM   #8
Just incase anyone else has the same issue, i replaced the EGR gasket and it fixed the problem, once i got it off it was obvious that was the issue.
LCMC Member
Old 12-02-2012, 01:04 AM   #9
Robbiemustang96's Avatar
What does am EGR do anyway and does my car have one?!?!?! Its a 98
Robbiemustang96 is offline   Reply With Quote
Old 12-02-2012, 01:13 AM   #10
Tyoung68's Avatar
Its a smog device and yes every new car has em its on your exhaust manifold
Old 12-02-2012, 07:56 AM   #11
jdavis96gt's Avatar
Region: West Virgina
I think it recycles unburnt gas, not 100% on that tho.
Old 03-14-2013, 10:51 PM   #12
100% correct, the EGR valve is the Exhaust Gas Recirculation valve
LCMC Member
11:51 AM
