Knocking sound - Mustang Evolution
Old 11-19-2012, 12:40 AM   #1
03Sixtang's Avatar
Region: Nevada
Knocking sound
Hey guys
As of recently I've been hearing a knocking sound that happens when I make somewhat sharp turns at low speeds. Obviously it's something suspension/steering related but I was wondering if any of you guys seen or heard this before and what the exact problem was. My buddy swears it's my ball bearings and I think it is possibly one of my tie rod ends going bad. Any ideas?
03Sixtang is offline   Reply With Quote
Old 11-19-2012, 01:09 AM   #2
1slosix's Avatar
ball bearings? does he mean ball joints? if so it's possible it's one if its more of a popping noise...especially when it comes to low speed cornering. check the grease bags on them and see if they are empty or busted. if empty just pack them with grease and see if that helps any...while you're at it check the tie rod ends but usually it's a ball joint
carving corners like a boss
Old 11-19-2012, 08:01 AM   #3
03Sixtang's Avatar
Region: Nevada
Okay, could there be any damage done to the ball joints? If so how much to fix?
Old 11-19-2012, 12:56 PM   #4
08SteedaQ350's Avatar
Originally Posted by 03Sixtang
Hey guys
My 300zx did this really bad at low speeds. Sounded like someone under te car hitting it with a sledge.
Needed new ball joints and tie rod ends.
08SteedaQ350 is offline   Reply With Quote
Old 11-19-2012, 01:25 PM   #5
03Sixtang's Avatar
Region: Nevada
did you do it yourself or did you pay a shop, if so how much?
Old 11-19-2012, 01:46 PM   #6
I just sold it to my uncle and let him fix it lol
Old 11-19-2012, 01:55 PM   #7
03Sixtang's Avatar
Region: Nevada
Haha I see, smart move. I'm trying to sell mine so I can buy my buddies cobra off him haha
Old 11-19-2012, 02:15 PM   #8
Yeah I upgraded to an 08 gt
Old 11-19-2012, 02:32 PM   #9
Jlope014's Avatar
Originally Posted by 03Sixtang View Post
Hey guys
I would guess shocks are worn and your control arm is hitting the undercarriage.
Could be loose sway bar also. Steering rack is a less likely and more expensive possibility.
These have been my knocking noise experiences anyways- except, thankfully, for the steering rack.
Jlope014 is offline   Reply With Quote
Old 11-19-2012, 04:22 PM   #10
03Sixtang's Avatar
Region: Nevada
It only makes noise when I turn at low speeds though. If the shocks were worn that bad and the control arm was hitting it would most likely make noise when I went over speed bumps as well which it doesn't. Because it happens when I turn is why I believe it's either ball joints or tie rod problems, it sounds like something is loose or a bolt snapped and something is wiggling around and making noise when I turn.
Old 11-19-2012, 04:36 PM   #11
Car in park. Wheels straight. Stand to the back side of your from tire and give the wheel a swift kick with your foot. If the tire moves forward, change your ball joints. You will also be able to hear it vibrate when you kick it if they are bad.
---------- Post added at 05:36 PM ---------- Previous post was at 05:35 PM ----------
If they are bad, you will see your wheel rock forward
That's my southern coonass diagnoses for bad ball joints
Old 11-19-2012, 07:03 PM   #12
03Sixtang's Avatar
Region: Nevada
Haha alright I tried you're way, nothin moves. When I kicked the drivers side front tho something rattled, it sounded like that aluminum plate behind the rotor
Old 11-19-2012, 07:08 PM   #13
Could be the problem. I have yet to crawl under my mustang to check everything out and see what it looks like. Only had it a month now.
Was just goin off general knowledge of working on past vehicles I've had
Get under there. Grab hold of some stuff and manhandle. Find out what's loose
Old 11-19-2012, 07:09 PM   #14
sLbxO143's Avatar
Just got my upper ball joint changed yesterday, at low speeds I would hear knocking and also when I would take my foot off of the brake it would also make a noise. It got so bad my steering wheel was also clicking when I turned. When I would turn the wheel it would also grind. The shop thought it could either be the outer tie rod end or the ball joint and It ended up being ball joint. I got it done for 250$ with an alignment as well. Hope this helps
sLbxO143 is offline   Reply With Quote
Old 11-19-2012, 07:45 PM   #15
jdavis96gt's Avatar
Region: West Virgina
Dam that's alot for a balljoint.
Old 11-19-2012, 07:51 PM   #16
sLbxO143's Avatar
Tell me about It, if I didn't wait so long before it went bad could of gotten it done for free. Hardly could drive car though because the noise kept getting louder n louder. Happy fixed now though
Old 11-19-2012, 07:56 PM   #17
jdavis96gt's Avatar
Ye better to get it fixed before it breaks.
Old 11-19-2012, 09:14 PM   #18
03Sixtang's Avatar
Region: Nevada
Well I decided to do some research on how to legit check if those ball joints are going bad. If anybody wants to do this in the future just to check, the best way to do it is to raise the car on jack stands. Put a little pressure up on the lower control arm with a jack. Then grab the top and bottom of the wheel and wiggle in and out. If there is any movement you've got a bad ball joint. Ima check mine tomorrow
Old 11-20-2012, 12:12 AM   #19
Dgerow12's Avatar
These cars have strut mounts not upper balljoints. And mustang balljoints are known to go every 25-50k miles more or less depending on the bumpyness of the area u drive in
Dgerow12 is offline   Reply With Quote
Old 11-20-2012, 12:44 AM   #20
1slosix's Avatar
which is why when mine start to go i'll be going with x2 balljoints
Old 11-21-2012, 07:14 AM   #21
Jlope014's Avatar
You can rent the press from autozone you get all the money back only took me 3 hours or so to change both sides along with front struts and springs, and im an idiot.
Funny though, mine squeaked. never heard them click/thump before.
Old 11-21-2012, 11:24 AM   #22
sLbxO143's Avatar
When I would turn my steeling wheel it would click and then when I was slowing down to turn it would actually be a grinding sound and thump because my ball joint boot was actually gone.
Old 11-21-2012, 11:46 AM   #23
kickerofdoom's Avatar
Mine fell off this summer but after I changed both of them
Old 11-22-2012, 08:01 AM   #24
Jlope014's Avatar
Lol the stock boots on those things are crappy. When I changed mine, they were half gone, and I thought that was as bad as it could get. Maybe thats why I just got the grinding noise occasionally. The clicking is new to me though. Learn something new every day
09:54 PM
