New 7.5 3.73 gears for $149.99 with a lifetime warranty - Mustang Evolution
Old 11-13-2003, 03:10 PM   #1
Send a message via AIM to Blue232
i found new 7.5 3.73 gears for $149.99 with a lifetime warranty even if you install them wrong. The thing is is that there from a 4x4 parts place and there for rangers. Just asking if the 7.5 has ever changed and if it will work in my car. Thanks
Sold the sixxer
Got a 2000 5sp Black GT. I love it.
Blue232 is offline   Reply With Quote
Old 11-13-2003, 03:50 PM   #2
Monkey's Avatar
nope, the ranger ones are completly interchangable in our cars
Old 11-13-2003, 04:34 PM   #3
Zim
You want to **** me?
Zim's Avatar
just make sure its not threaded the opposite way for the rangers front differential... make sure its the one that goes in the rear diff, otherwise youll be going backwards in drive
I like toys
Old 11-13-2003, 05:04 PM   #4
Dang man, if they work on stangs, let me know, I'll order them.
Old 11-13-2003, 05:11 PM   #5
Zim
Zim's Avatar
they do... its the same size and everything, you just have to make sure you get the correct direction of the gearing
I like toys
Old 11-13-2003, 07:44 PM   #6
Danger Dude's Avatar
Mine are out of a Ranger. I got them from Terry at Midwest. Rangwers with towing packages have 3.73 or 4.10 gears.
Old 11-13-2003, 07:46 PM   #7
Hm...my dad has a ranger with 4.10's in it...I may switch gears with him...I wonder if he'll notice if I come home one weekend and have both my car and his truck in the shop out back....
Old 11-13-2003, 07:46 PM   #8
If he uses it for towing he will definately notice
Old 11-13-2003, 07:49 PM   #9
Ha, we use it for towing our 4 wheeler on a trailer for hunting, stuff for fire dept, a 20 foot bass boat...dang, he'll notice. I'll just say it's his truck missing again lol. I just got done a couple of months ago taking the head apart and redoing most of it cause it was missing so bad. Ha ha, I'll figure out something
Old 11-13-2003, 07:49 PM   #10
Zim
Zim's Avatar
arent you running an 8.8 rear end corey???
I like toys
Old 11-13-2003, 07:50 PM   #11
Now to find a weekend to go home and find him a vehicle to drive that weekend... well I'm going home this weekend, but really don't feel like messing with his stupid truck
Old 11-13-2003, 07:56 PM   #12
Hell no I am a 7.5er Pete at fordchip is running the original 7.5 in his car and he gives it hell he is well over 300 HP
Old 11-14-2003, 11:54 AM   #13
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
The T-loc you get for the mustang is just a t-loc out of a ranger. It should work fine.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 11-14-2003, 11:57 AM   #14
The place that the gears are from is www.4wheelparts.com. They have the gears for 149.99 and the master install kit which comes with new baring and shims and everything else for $78.99. These prices are alot cheaper than any place i have seen. and they have 4.10s and 4.56 and there still priced at $149.99. You can't beat it. It also come with a lifetime wanrranty on the gears. EVEN if you install them wrong. THey will replace them.
Sold the sixxer
Old 11-23-2006, 12:54 PM   #15
Re: New 7.5 3.73 gears for $149.99 with a lifetime warranty
does it matter what year of ford ranger you get a rear end from
cause i have a 01 mustang
ryanxup is offline   Reply With Quote
Old 11-23-2006, 12:58 PM   #16
Zim
Zim's Avatar
This is an old thread, but thanks for searching... you're one of the few
It shouldnt matter as long as its a 7.5" rear end.
I like toys
Old 11-23-2006, 04:27 PM   #17
no problem
thanks
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Going to the concert of a lifetime!!!! woooott!!!! fast64 The Bar 8 08-23-2005 05:06 PM
Warranty STEVE The Bar 18 06-04-2004 10:08 PM
10:19 PM
