Windstar intake swap - Mustang Evolution
Old 11-21-2012, 09:14 PM   #1
SN95V600's Avatar
Ok guys im still working on this shizz only problems holding me back is the spacer already getting wire to extend the iac and tb wiring......my thing is i will be deleting egr and pcv system.....do i still tap into the bottom the windstar intake or just use the tip were the iac would have sat?
---------- Post added at 12:14 AM ---------- Previous post was at 12:12 AM ----------
Should i buy caps iac relocation bracket and need help fabing uo the throttle cable bracket any ideas?
SN95V600 is offline   Reply With Quote
Old 11-21-2012, 10:01 PM   #2
SN95V600's Avatar
I meant vapauto wen i said caps lol
Old 11-25-2012, 03:13 PM   #3
1987mustanglx50's Avatar
Does any one know if I can use Tue windstar upper intake on a 2004 mustang v6 and from what year winstar do I use it from and is the upper intake The only thing I need from The windstar I would really much appreciate The help thanks
1987mustanglx50 is offline   Reply With Quote
Old 11-25-2012, 03:34 PM   #4
03Sixtang's Avatar
Region: Nevada
Yeah you can use the intake on an 04, you're gona need the throttle body and the bolts to bolt it down, along with egr bracket and the iac solenoid and the intake gaskets.
03Sixtang is offline   Reply With Quote
Old 11-25-2012, 03:52 PM   #5
Cool thank you for your help
Old 11-25-2012, 04:27 PM   #6
03Sixtang's Avatar
Region: Nevada
No prob dude
Old 11-26-2012, 06:44 AM   #7
willrad00's Avatar
I kept everything and the relocation bracket was a must. The engine bay got pretty cramped after the windstar so anything to spread things out away from the manifold was helpful.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
11:59 AM
