Brake issues! HELP! - Mustang Evolution
Old 11-23-2012, 11:27 PM   #1
BigT03's Avatar
Brake issues! HELP!
I have a 2001 V6 that I love more than my gf(I pray she won't read this). But the brake system is messing up. It's got a new master cylinder, new calipers, new rotors, new pads, and new hoses. All this was done before I bought it 2 months ago. But 3 of the 4 calipers are locked up/don't work. And the proportioning valve is leaking(not bad, just a lil). I don't make a lot of money so is there a cheap way to fix this? Sears didn't know if fixing the leak would make the calipers work. All they said was I need to do a fluid exchange/flush and replace the valve. Then see what happens. If the calipers still won't work then I gotta replace them. Maybe this is a sign to upgrade to the Cobra brake system? Hard to find Mustangs in junkyards tho. So if ya got extra parts hit me up. I won't pay an arm and a leg. So pls be reasonable.
'Arion' 2001 Mustang V6 5sp
I am Big-T, and I approve this car!
BigT03 is offline   Reply With Quote
Old 11-23-2012, 11:36 PM   #2
1slosix's Avatar
replace the valve...do a full bleeding to get any air out of the system. see how that works for you. If you decide to replace the calipers honestly i'd stay oem. a NE has decent calipers and with the right pads, fluid, and brake lines they will be a very nice performance setup.
carving corners like a boss
Old 11-24-2012, 12:06 AM   #3
Eturner's Avatar
+11. Be sure to start with the master cylinder first!.. Might have some air up in there!..
Old 11-24-2012, 12:13 AM   #4
BigT03's Avatar
So the problem is the valve? Once I replace it and do a flush the other 3 calipers will work? And where is the valve at? Also I know OEM brakes are good on that car. But I plan to get 18s on the car and will need bigger brakes. So the Cobra being setup for 17s seems like a good choice. I just want this car to be safe.
Old 11-24-2012, 04:15 AM   #5
Butch's Avatar
Region: New Mexico
Can't go wrong with 13" rotors. Check and make sure the piston is pushed back all the way, sometimes you just never know
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 11-24-2012, 08:24 AM   #6
1slosix's Avatar
i don't think it's an actual valve on our cars but built into the MC...i know they make after markets though. have you even bleed the brakes yet since buying the car? if not go ahead and do so...who knows if the original owner did the brake job right
Old 11-24-2012, 08:27 AM   #7
deadsp0t's Avatar
You may need that brake tool to spread the calipers....
That's unimpressive
Old 11-24-2012, 08:28 AM   #8
1slosix's Avatar
the fronts he can c-clamp...the rear he will need a piston tool
07:45 PM
