EXHAUST HELP - Mustang Evolution
Old 11-26-2012, 06:34 PM   #1
Crowned1's Avatar
Soo ironically enough i post a thread about my new exhaust but i have a problem with my stock one. So here's what happened, i accelerated and i heard a loud pop, my car then started to rumble and sound like a loud race car or motorcycle, i pulled over and noticed the rumble was coming from underneath the car and i felt the but more on the right side. It sounded as if it was coming from the cats, i felt each catalytic converter and the left one was hot and right wasn't nearly as hot as the left as if there was a hole or something was disconnected in it. When you give it gas you can feel air from the right side of the car by your feet and it smells like exhaust fumes. Anyone know what this is?? It's a 2004 v6 btw. Thanks!
Crowned1 is offline   Reply With Quote
Old 11-26-2012, 07:04 PM   #2
ForsakenProto's Avatar
Stock exhaust is known to crack on the 99-04 mustangs. Condensation from the AC drips on them and will crack either on the header or below it on the mid pipe
ForsakenProto is offline   Reply With Quote
Old 11-26-2012, 08:26 PM   #3
Venomouz831's Avatar
Sounds like a cracked manifold
)02 Gt, Founder of WE2G
Old 11-26-2012, 08:36 PM   #4
Crowned1's Avatar
hopefully its not the header
Old 11-27-2012, 09:04 AM   #5
austinknoll's Avatar
Please tell me there is a way to fix this. I hear it hit mine as well but mine hasn't blown cause I don't use the AC a lot. Do I just need some rubber tubes or something?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 11-27-2012, 09:17 AM   #6
The pass manifold breaks at the collector. You will need a new manifold/header to fix it.
To prevent this problem ford's solution is to put a piece of gutter under the drips to route them elsewhere
Old 11-27-2012, 09:43 AM   #7
Pretty much, find a way to keep the water away from the exhaust, and we also install a hanger right before the Y on the mid pipe to relieve stress on the piping itself
Old 11-27-2012, 09:53 AM   #8
Good idea. When mine broke I was running true duals so the pass exhaust was dragging the ground. Made for an interesting drive home, tied the exhaust up with speaker wire from my subs.
exhaust
01:52 AM
