disc brakes and 2.73 ratio? - Mustang Evolution
Old 05-08-2008, 12:45 PM   #1
I'm doing a custom project, and i'm looking to find a mustang rear end with disc brakes, solid axle and a ratio of 2.73 or less in a 7-1/2" rear end...
Can anyone tell me if the V6 mustang's ever came with such a thing?
Thanks kindly,
-mark
unclejemima is offline   Reply With Quote
Old 05-08-2008, 01:15 PM   #2
Herbstang's Avatar
Re: disc brakes and 2.73 ratio?
Here's the rear ratios
Rear Gear Ratio Factory Axle Code
2:73:1 Ratio 8M
3.08:1 Ratio YZ
3.27:1 Ratio 5E
3.55:1 Ratio 2K
3.73:1 Ratio 6W
4.10:1 Ratio N/A
Manual Transmissions with 7 Tooth Drive Gear
1983-1989 T-5 OEM
Pre 1993 T-5 Aftermarket
1996-1998 Cobra T-45 OEM
All Tremec Transmissions
Part Number Description
C0DZ-17271-A 2.73 Gear Ratio / Maroon 16 Speedo Gear
C0DD-17271-B 3.08 Gear Ratio / Yellow 18 Speedo Gear
C0DZ-17271-B 3.27 Gear Ratio / Pink 19 Speedo Gear
C1DZ-17271-A 3.55 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A 3.73 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393 4.10 Gear Ratio / White 23 Speedo Gear
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
C0DD-17271-B 2.73 Gear Ratio / Yellow 18 Speedo Gear
C1DZ-17271-A 3.08 Gear Ratio / Black 20 Speedo Gear
C4OZ-17271-A 3.27 Gear Ratio / Red 21 Speedo Gear
Jeep Part #j3167393 3.55 Gear Ratio / White 23 Speedo Gear
Jeep Part #j3167393 3.73 Gear Ratio / White 23 Speedo Gear
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
D0AZ-17271-A 2.73 Gear Ratio / Blue 16 Speedo Gear
C7AZ-17271-B 3.08 Gear Ratio / Gray 18 Speedo Gear
C7VY-17271-A 3.27 Gear Ratio / Tan 19 Speedo Gear
C8SZ-17271-B 3.55 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B 3.73 Gear Ratio / Purple 21 Speedo Gear
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
C7AZ-17271-B 2.73 Gear Ratio / Gray 18 Speedo Gear
C8SZ-17271-B 3.08 Gear Ratio / Orange 20 Speedo Gear
D0OZ-17271-B 3.27 Gear Ratio / Purple 21 Speedo Gear
Old 05-08-2008, 01:16 PM   #3
You can find a 94-98 V6 mustang rear end. It's a 7.5 open diff, 2.73 gears, disc brakes on most of them.
Old 05-08-2008, 01:26 PM   #4
thats great, thanks for the info!
Is it a solid rear end?
What size are the rear disc brakes (smallest size rim size i can run without clearance issues...?
Thanks again!
Old 05-08-2008, 02:31 PM   #5
Scut95's Avatar
Thats a solid rear....i believe the smallest rims from the factory are 15's so i wouldn't run any smaller than that, you could run into issues if you do....as for break size im not sure but i know they're not too big
Old 05-12-2008, 01:33 PM   #6
lowflyn, you say 94-98. Was this same combo (7.5 & 2.73) avail on the newer 99+ V6 mustangs as well, or just the 94-98's?
Thanks!
-mark
10:53 PM
