V6 to v8 swap? - Mustang Evolution
Old 11-30-2012, 09:22 AM   #1
Berry_Eggo's Avatar
V6 to v8 swap?
Want to swap to a v8 but not sure what other mods will have to be done to make the swap? Do I have to swap my transmission from a v8 as well ?
Berry_Eggo is offline   Reply With Quote
Old 11-30-2012, 12:41 PM   #2
ForsakenProto's Avatar
Transmission, rear end, k member, wiring harness, computer, instrument cluster. All that fun expensive stuff. In most cases its easier just to buy the car, than to do the swap. That being said, im doing my own swap whenni get the time. Already have my 4V 4.6, so itll be soon
ForsakenProto is offline   Reply With Quote
Old 11-30-2012, 12:42 PM   #3
Venomouz831's Avatar
Try to get a car with everything needed for the swap
)02 Gt, Founder of WE2G
Old 11-30-2012, 12:45 PM   #4
And this isnt a one day job. Chances are, you're gonna have to pull the engine and adjust things one or two times during the install. If you've never done this before, have someone with you who has, takes alot of the guess work out of it.
Old 11-30-2012, 01:03 PM   #5
Berry_Eggo's Avatar
I see, so it would just be easier to get a new one?
Old 11-30-2012, 01:06 PM   #6
Yes it would
Old 11-30-2012, 01:10 PM   #7
Absolutely.
Old 11-30-2012, 02:59 PM   #8
JetLife 01GT's Avatar
http://www.allfordmustangs.com/forum...ere-first.html check this out so you know what you'd be in for
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-30-2012, 06:52 PM   #9
SN95V600's Avatar
i think the only reason i would wana do this is because i wouldnt have to worry about a new car and having a monthly note that way we build it and its paid off and wnt be so pissed wen it breaks lol i wana do a 4.6 3v swap what are yall guys opinions on the swap
SN95V600 is offline   Reply With Quote
Old 11-30-2012, 08:00 PM   #10
lemons95's Avatar
tranmission and rearend are recommended. I don't think anyones ever tried to see how long the V6 tranny and rearend hold up.
If you did re-use the stock rearend from your V6 with a V8 you'd probably get close to 26 or 27 mpg hwy.
I think I heard someone say the transmission holds up to like 250or 275hp.
The guy with twin turbo roush V6 on youtube said his transmission broke after 650hp. I think roush used a different transmission though.
Old 12-01-2012, 06:40 AM   #11
SN95V600's Avatar
i have 4rw70 so iv read gts came wit these trannys they changed but early yrs used 4rw70 i think ima keep the 7.5 i wont beat on it till i get the 8.8 just so i can do the engine swap i wana buy frpp wire harness and ecu from ford racinig its like 1,200
Old 12-02-2012, 03:53 AM   #12
davidcseifert's Avatar
Region: Arkansas
As for the transmissions modular and V6 use a completely different bolt pattern (the V6 uses a sbf pattern exactly like the 302) so you will not be able to even try that..
The 4R70W trans does not break at 250hp lol it takes A LOT to kill one as long as you don't overheat it (V6 and V8 4R's have same internals just different casing which allows them to attach to the modular bolt pattern, and have a different tq converter supposedly)
Roush doesn't do anything to the transmissions
I was about to link this haha puts things into a better perspective for sure
blower/new cam soon
Old 12-02-2012, 05:13 AM   #13
Stanglover1966's Avatar
I might as well be straight up honest with you. Do not do the swap. Just sell your car and buy the same model with a v8. By the time you're done with the swap. You would have spent enough money to buy 2 GTs.
Stanglover1966 is offline   Reply With Quote
Old 12-02-2012, 01:09 PM   #14
lemons95's Avatar
Sometimes people don't have that option. Theres some ****ty gt's in my area but I don't have the money for them either.
Sometimes they might already have most of the parts at hand to do the swap.
Old 12-02-2012, 05:53 PM   #15
Lol. How many horses is your pony pushin David?
2001 GT
Old 12-02-2012, 07:56 PM   #16
Region: Arkansas
253hp/261tq, std #'s
blower/new cam soon
Old 12-03-2012, 03:46 AM   #17
NICE MAN!!
2001 GT
Old 12-03-2012, 08:52 AM   #18
Region: Arkansas
NICE MAN!!
Got a couple more things I'm putting on next, better cam and a little juice
blower/new cam soon
Old 12-03-2012, 07:52 PM   #19
SN95V600's Avatar
Can we hit 300 n/a on a 4.2? Still looking for one havent found one yet i wrote kyoe stating i need a cam and some p/p wrk
Old 12-03-2012, 07:55 PM   #20
Region: Arkansas
278 SAE rwhp is the N/A record, it's Mr. Yentzers V6 fox
blower/new cam soon
Old 12-03-2012, 08:10 PM   #21
SN95V600's Avatar
Dam 278? Thats not bad what about tq? Dam 278 and a 150 shot? Dam can u help me source a 4.2?
---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
R u talkin about ssm v6?
---------- Post added at 11:10 PM ---------- Previous post was at 11:09 PM ----------
If i get a 99 4.2 do i still need 01 pick up tube and oil pan? Im just looking to get the 4.2 swap top end my stablngs headers put a 01 oil pan and drop it in is that it?
Old 12-03-2012, 08:11 PM   #22
Region: Arkansas
Not sure on tq, but hp was through a stalled auto trans so it could be higher with a stick, but more problems drag racing with a manual though
Try LKQ or a local junkyard, sometimes craigslist may have one
And yes Yentzer is Tom Y from SSM
blower/new cam soon
12:48 AM
