exhaust question - Mustang Evolution
Old 12-02-2012, 10:28 AM   #1
Crowned1's Avatar
i just got my exhaust on yesterday i took the cats off and went with the flowmaster divorced dual exhaust. I've been noticing high idles at high speeds when I'm on the highway going 60 it's idling around 2100 rpm. is that normal? and also its a 2004 auto v6. how can i fix this? thanks!
Crowned1 is offline   Reply With Quote
Old 12-02-2012, 11:05 AM   #2
1slosix's Avatar
When they cut the cats they could of josseled one of the upstream o2s loose slightly...when you idle where does the tach sit...right at 700 is normal for a stock.sixxer
carving corners like a boss
Old 12-02-2012, 07:07 PM   #3
Crowned1's Avatar
It's sitting right around 900 rpms
Old 12-02-2012, 08:41 PM   #4
ProudSixxer26's Avatar
AMAZING choice how much did it cost and post a vid!
ProudSixxer26 is offline   Reply With Quote
Old 12-02-2012, 09:21 PM   #5
1slosix's Avatar
a bit high...clean your MAF, IAC, and TB and see if it helps...this idle issue could all be a coincedence
Old 12-03-2012, 12:15 AM   #6
lemons95's Avatar
flowmasters 10's? 40's or what?
Old 12-03-2012, 06:38 AM   #7
Crowned1's Avatar
$425 w/ the welding to fix the piping above the right cat and i will ASAP
---------- Post added at 07:37 AM ---------- Previous post was at 07:37 AM ----------
i will try this and let you know what happens!
---------- Post added at 07:38 AM ---------- Previous post was at 07:37 AM ----------
40's!
Old 12-03-2012, 08:25 AM   #8
Crowned1's Avatar
there's a picture of the tips ^__^
Old 12-03-2012, 10:44 AM   #9
How far do the tips go out
Old 12-03-2012, 11:53 AM   #10
Crowned1's Avatar
about two fingernail lengths out, that'a the most accurate measurement i could think of while sitting here in class lol
Old 12-03-2012, 01:20 PM   #11
Surffer227's Avatar
How do you idle a auto on the highway?
Surffer227 is offline   Reply With Quote
Old 12-03-2012, 02:00 PM   #12
Crowned1's Avatar
what I mean by that is that the RPMs are higher when I let off the gas at 60 then they were before i got the exhaust put on. For example, before the exhaust when i got to 60 and let off the gas it would go down to roughly 1600 RPMs but now with the exhaust and i let off and it's stuck around 2100 RPMs, does that make sense?
Old 12-03-2012, 03:16 PM   #13
Surffer227's Avatar
Ohh, sounds like IAC
Old 12-03-2012, 03:31 PM   #14
Close to mine 1 1/2
Old 12-03-2012, 04:54 PM   #15
Crowned1's Avatar
what is that and how do I just need to clean it? if so, with what?
exhaust
08:26 AM
