Cat delete kit - Mustang Evolution
Old 12-04-2012, 05:00 PM   #1
Mr_Trigger3.8's Avatar
Cat delete kit
Hey guys I'm going to be putting a cat delete kit on my 03 mustang and I was just wondering if I would have to do anything with the o2 sensors. Anybody have experience in this sort of thing?
Mr_Trigger3.8 is offline   Reply With Quote
Old 12-04-2012, 05:01 PM   #2
Doe_Rae_mi's Avatar
You would probly be better off getting an offroad pipe
Old 12-04-2012, 05:05 PM   #3
I already have offroad x pipe with flow super 44s
Old 12-04-2012, 05:06 PM   #4
Doe_Rae_mi's Avatar
I think I may be misunderstanding what a cat delete kit is lol. It's not a kit that helps u delete your cats?
Old 12-04-2012, 05:27 PM   #5
The kit I'm installing is basically just a section of pipe with flanges to bolt up in place of the cats. So when I need to smog it I just bolt the cats back up.
Old 12-04-2012, 07:47 PM   #6
Crowned1's Avatar
from my experience of straight piping my cats you will have to make some new holes for the o2 sensors. got any pics?
Crowned1 is offline   Reply With Quote
Old 12-05-2012, 01:33 AM   #7
davidcseifert's Avatar
Region: Arkansas
Two options, if you have a tuner, have the rear O2 sensors shut off, or buy mil eliminators that plug in between the sensor and wire harness to make it falsely read it still has cats
If you don't have a place for the O2's in the new pipe you can always wrap them and Ziptie it out of the way to protect them until you have to use it again
blower/new cam soon
Old 12-05-2012, 04:10 AM   #8
Yea I figured I'd have mil problems. I looked up mil eliminators on Americanmuscle.com and they're not too pricey so that's probably what I'll end up doing. Hopefully I won't need to drill any holes. Just more opportunity for exhaust leaks. Haha 03 mustangs have enough exhaust leak problems as it is.
---------- Post added at 04:10 AM ---------- Previous post was at 04:09 AM ----------
I don't have any pics at the moment. I'll try to throw some up soon though.
Old 12-05-2012, 04:24 AM   #9
Off road X pipes don't have cats.
If your X pipe has cats then its a catted X pipe.
You may want to double check to make sure... before you buy something.
02V6Mustangg is offline   Reply With Quote
Old 12-05-2012, 10:53 AM   #10
Yea it's definitely catted X.
10:05 AM
