Blown up? - Mustang Evolution
Old 12-05-2012, 08:02 AM   #1
Surffer227's Avatar
Blown up?
Has anyone one here blown one of these engines? I hear a lot about my buddies blowin up or rebuilding their toyotas n ****, but I've never realy herd much about these 3.8s blowin up, in about to go on boost and would like to know the weak points on the engine
Surffer227 is offline   Reply With Quote
Old 12-05-2012, 09:22 AM   #2
Billymich's Avatar
This is just a guess(I have a 5.0) But depending on the age of your car and mileage, you may want to do a full rebuild, check block/magnaflux, forged pistons with lower compression, new bearings... It all depends on how much boost you want to run. You could probably get away with 5psi of boost without doing anything to your bottom end, I'm sure someone more knowledgeable will correct me if im wrong. Good luck !
Old 12-05-2012, 09:58 AM   #3
davidcseifert's Avatar
Region: Arkansas
I've seen someone bend all six rods at once (factory motor) because it started detonating and well.. That's where it ended up
The blocks are very strong not very often do they give, just like other motors abuse it before it warms up any and you can have problems and crack it
The rods and pistons are the main week points, whereas the crank is good for even the big 600+ rwhp monsters, it has never been broken to my knowledge
On stock motor if you have a really really good tune you can push 450rwhp if its in good shape and not fret too much, but generally after 400 it's a good idea to upgrade to a forged rotating assembly
blower/new cam soon
Old 12-05-2012, 11:11 AM   #4
Surffer227's Avatar
Thanks, so 6-8 is what I hear is reasonable boost for a stock engine, so lets say I wanna bump it to 10-12 once in a while but wanna keep my reliability, what should I do? I heard something about head gaskets going out, but I don't see how boost would do that... What could I do to keep my reliability while on boost
Old 12-05-2012, 11:18 AM   #5
Region: Arkansas
10-11 is DD status lol on a stock motor you'll make about 300rwhp with a supercharger at that, probably 320 range on turbo because more efficient, head gaskets are a common problem but don't require much to prevent, don't overheat and if you're doing a head swap look into arp head studs
blower/new cam soon
Old 12-05-2012, 06:07 PM   #6
Surffer227's Avatar
So I could run 10-11 completely stock? And not worry?
Old 12-05-2012, 11:22 PM   #7
Region: Arkansas
Just make sure you go to a good dyno tuner, otherwise yeah not much worry
blower/new cam soon
Old 12-05-2012, 11:29 PM   #8
Surffer227's Avatar
Well I was thinkin of tuning myself
Old 12-05-2012, 11:31 PM   #9
1slosix's Avatar
noooo sir lol unless you have been doing dyno tunes yourself for a while....i'd only trust someone that does this all day everyday
carving corners like a boss
Old 12-05-2012, 11:52 PM   #10
Surffer227's Avatar
Isn't it just pretty much fuel pressure I'm adjusting?
Old 12-06-2012, 12:12 AM   #11
lemons95's Avatar
I blew my engine up on a 400+ mile long trip with my dad. We were 20 miles away from are destination and it was nothing but smooth road. no more hills or anything.
The previous owners before me left it sitting for over year. It looked like it rusted from inside the water jacket and into the cylinder.
Old 12-06-2012, 12:23 AM   #12
Region: Arkansas
tuning yourself N/A sure less risk, FI? not a first time thing at all.. maybe if you have someone experienced helping you but not alone
blower/new cam soon
Old 12-06-2012, 12:28 AM   #13
Surffer227's Avatar
My auto teacher tuned his supercharged corvette back when he built it, and he's a very smart guy, I trust him to help me
Old 12-06-2012, 12:32 AM   #14
Region: Arkansas
in that case, sure, someone with experience is a great plus, just be careful like always lol
blower/new cam soon
Old 12-06-2012, 10:43 AM   #15
Surffer227's Avatar
Have any of you tuned yourself?
Old 12-06-2012, 10:53 AM   #16
kickerofdoom's Avatar
It's all about watching the air fuel ratio making sure it doesn't lean but experience helps in all aspects
Old 12-06-2012, 11:04 AM   #17
Surffer227's Avatar
Yea I'm gonna put a 255 pump in and try to max out my stock injectors, you get a finer mist that way, if you have such a big injector with no pressure it's harder to burn the fuel, but I plan on starting the tune with pressure full and just turning down little by little until it almost goes lean
Old 12-06-2012, 01:51 PM   #18
Region: Arkansas
With that comment I would call you not so bright, stock injectors on a boosted motor? Lmao you'll need cobra injectors at least.. I'm barely using the stock 21# injectors in my N/A car, boost requires more injector than N/A situations
blower/new cam soon
Old 12-06-2012, 02:02 PM   #19
Surffer227's Avatar
Well I'm gonna try it, see how code I can get, worse comes to worse ill get some injectors
Old 12-06-2012, 02:12 PM   #20
Region: Arkansas
Don't blow it up
blower/new cam soon
12:26 PM
