Just Installed X-Charger and Car Wont Start - Mustang Evolution
Old 05-12-2008, 07:26 PM   #1
Well the X-charger is installed on my 2005 ford mustang after two rough days of working on it. Now my issue is that I can't get my car to start. The engine cranks, I get compression, I just can't get it to sustain. I followed the instructions the best I could. I'm not sure whats keeping things from starting. Anyone have any ideas suggestion or experience? I'm new here by the way. Any help is appreciated
Thanks
Aaron
ancapaaron is offline   Reply With Quote
Old 05-12-2008, 07:37 PM   #2
Re: Just Installed X-Charger and Car Wont Start
I just googled xcharger and came up with nothing.... got any info on it? Where it's sold?
Old 05-12-2008, 07:41 PM   #3
I bought the steeda kit. Its an mp90 supercharger.
X-Charger Supercharger Kit - V6 - '05-'08 Ford Mustang
BTW I like your choice for president.
Old 05-12-2008, 07:50 PM   #4
you try giving them a call to see if its a known issue~ i would check vacuum to see if its in range
Old 05-12-2008, 07:53 PM   #5
When I first installed it the belt popped off because the idler bracket was a bit ,loose is it a possibility that it could be timing? I fixed the idler bracket and got the pulleys re-aligned. Whats the best way to check vaccum without guages?
Old 05-12-2008, 07:55 PM   #6
Sounds like a vacuum issue to me too. It's getting enough spark to turn over and start...
Old 05-12-2008, 07:57 PM   #7
Whats the best way to remedy a vacuum issue if its not the timing.?
Old 05-12-2008, 08:00 PM   #8
A gauge is the only true way to do it and the easiest... you can probably go to Autozone and possibly rent one... if not you can pick one up for less than 60 dollars. If you are installing things like a Supercharger you'll probably need to use it again eventually
Old 05-12-2008, 08:04 PM   #9
Would I have to pull the supercharger up and try to reseal it if its a vacuum leak? I'm a complete n00b so sorry for all the questions.
Old 05-12-2008, 08:24 PM   #10
Well a vacuum leak can come from many places... like a hose that isn't hooked up properly or has a hole in it.... the first thing though is to figure out if you have a leak or not at all.. then go from there.
Old 05-12-2008, 08:26 PM   #11
Also I can't get the engine to turn over so how I would I know that it was a vac problem with a guage? I'm really confused
Old 05-12-2008, 08:41 PM   #12
MonteCitan's Avatar
What sort of gasket did they ship with the supercharger? When I put the intercooler on the buick I had a real hard time getting it to seal properly with the garloc gaskets they shipped (green, pretty thick) ended up going back to two of the stock fiber style gaskets and instant success...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-12-2008, 08:48 PM   #13
They shipped these pretty thick gaskets. I don't know what brand they were. Its a possibility.
Old 05-12-2008, 08:53 PM   #14
Perhaps I didn't gap the new spark plugs correctly... Would something like this be the cause of the engine not being able to start?
Old 05-12-2008, 09:56 PM   #15
if the engine isnt turning over then its most likely an electrical issue check all electrical connections, not sure i know when i installed the supercharger on my mustang it turned over but wouldnt start, my problem was i didnt clean off the terminals well enough when i installed the preprogrammed chip, so i took it out and cleaned them off better and it works fine. if the engine wont turn over at all check your battery to see if its good, ( ive left the door open too long doing things that ran down my battery) if the battery is good then check your connections at the alternator. check battery and engine grounds, if this is all good get back to me and ill see what i can come up with
jedwards242000 is offline   Reply With Quote
Old 05-12-2008, 09:56 PM   #16
This is where I'm going to start I think....thanks for helping me brainstorm guys. If regapping the plugs doesn't work I'm going to see what I can do to fix vacuum. Maybe I'll post if I'm successful in getting everything running tomorrow. It would make me happy as its one day before my b-day, and I've been having a rough month.
Old 05-12-2008, 09:58 PM   #17
Yeah exactly...I'm thinking its electrical...I get compression and all that good stuff. I'm going to pull all six plugs tomorrow and regap them. The instructions to the x-charger manual call for .035 and I wasn't sure how to regap correctly though but my buddy has a regapping tool! I'll go from there.
Old 05-12-2008, 09:58 PM   #18
also with a good battery your car should star without drive belts for a short period of time. so i dont think the loose pulley had anything to do with it.
Old 05-12-2008, 10:03 PM   #19
Yeah it wouldn't run at all when it was flinging the belt off. I was able to fix the belt problem at least.
Old 05-12-2008, 11:31 PM   #20
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
I'll go with the electrical problem. What kind of tuner did the supercharger come with to reflash your ECU?
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 05-13-2008, 06:11 AM   #21
It came with the SCT Excalibrator II.
Old 05-13-2008, 06:12 AM   #22
05RedDevil's Avatar
Did you load the tune correctly?
Some show. Some go.
Old 05-13-2008, 06:22 AM   #23
I plugged the tuner into the ODB port and flashed...there wasn't any additional instruction on that.
Old 05-13-2008, 07:26 AM   #24
i would check on the tune loading as well to make sure that it loaded correctly~
Old 05-13-2008, 10:53 AM   #25
im confused is the engine turning over like cranking when youu turn to start it ? or is nothing happening
Old 05-13-2008, 11:33 AM   #26
Yes its cranking and it cranks hard, but it will not start.
Old 05-13-2008, 11:33 AM   #27
I'm checking on the tune. I contacted explorer express(the people who put together the kit) today, to see if they can help.
Old 05-13-2008, 08:08 PM   #28
I was able to fix it! I misread the new spark plug wire layout in the directions. Its all fixed now and the car is purring like a kitten with the new supercharger on. Thanks for all the help guys.
Old 05-13-2008, 11:40 PM   #29
great now time to have fun id still get it dyno checked to check air/fuel ratio and with any boost project i would install a vacuum/ boost guage just recommendation,
installed new bbk udp and car wont start help lvstreetkilla Pre-2005 V6 Mustang 0 08-19-2008 08:59 PM
Car wont start iwannagofast 1996-2004 Mustang GT 3 03-03-2008 09:34 PM
Car wont start!!! eNvy Pre-2005 V6 Mustang 5 04-29-2004 07:19 AM
help: hit a curb, car wont start. mexor The Bar 6 04-10-2004 08:18 PM
Car wont start, help: Rellik Pre-2005 V6 Mustang 28 11-30-2003 02:05 PM
10:57 AM
