Mass air upgrade: - Mustang Evolution
Old 11-13-2003, 08:09 PM   #1
Send a message via AIM to ASSEMbler
Mass air upgrade:
The mass air upgrade, what is this "clalibration" of the unit?
It seems to use the stock electronics, and the metal sensor base, what is different than if I went to a junkyard and got a larger mass air and installed it?
SIG REMOVED FOR THE PRUDE
ASSEMbler is offline   Reply With Quote
Old 11-13-2003, 08:17 PM   #2
Danger Dude's Avatar
On a stock motor you will gain nothing with a larger MAF. But the MAF has to be calibrated for the injector size on your car or have a Chip burned to reprogram the MAf.
Old 11-13-2003, 08:21 PM   #3
Well thing is if I get it now with the manifold, when I go forced I won't need to do that part over again.
Old 11-13-2003, 10:40 PM   #4
1) wont gain anything n/a
2) will cause more problems because you still have to have it calibrated for your injectors, and not many people like to do it.
3) hold off until you are actually installing the blower to put one on.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 11-14-2003, 05:15 AM   #5
It is way more hassle and money than it is worth !!!
Old 11-15-2003, 12:50 PM   #6
theoretically any mas air will work on any car with taht type of air inlet design...it sends a signal to the ecu...the problem is the ecu has to know what to do with that signal. by calibrating the signal to the correct injector size it then knows how much fuel to put in the mix, you cant just slap on one and go.
mass air info help please xpunisher1x 1979-1995 Mustang GT 4 04-15-2009 11:27 PM
GT MAss air? 232stang01 Pre-2005 V6 Mustang 16 03-12-2005 05:59 AM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 09:24 AM
Mass Air Meters BrooksPS Pre-2005 V6 Mustang 18 03-15-2004 05:39 PM
04:46 PM
