Which sensor is this and how should it be wired? - Mustang Evolution
Old 12-06-2012, 09:19 AM   #1
Hello Stang folks. I bought my 1998 Mustang 3.8l earlier this year, and well, lets say I was big eyed and didn't see anything major.... now I'm seeing how many little projects there are! Lets start with this one.
I have no idea whether it happened recently because I didn't notice it before, but I noticed this sensor the other day and from what I can gather its either the Coolant Temperature Sensor or Air Charge Sensor, but it only has one pin in it.
The car seems to be running fine, no real noticable idle problems or anything, but I'm sure it needs a second wire attached right? Does anyone know what it is, and how I should wire it back to specs? Thank you.
Name:	2012-12-05 15.05.03.jpg
Tigre is offline   Reply With Quote
Old 12-06-2012, 10:41 AM   #2
Surffer227's Avatar
That is for coolant, if I were you I'd follow the wire back as far as I can, if there is another wire in that Sleeve that got cut somehow, I'd just buy the new sensor n install it, but if there's no other wire I say leave it, does the temp gauge on your dash work?
Surffer227 is offline   Reply With Quote
Old 12-06-2012, 11:15 AM   #3
Thank you so much Surffer, I really appreciate your help!!
The temp gauge always has read right in the middle. I will look more carefully and make sure it is coming up to temp correctly. I will check it out at lunch and let you know, but I do know that the wire that you see connected to the sensor, has a bared spot just inside of that sheathing. Must have come into contact with the engine at some point.
Old 12-06-2012, 12:21 PM   #4
95v686gt's Avatar
I got a 95 with the same engine. Its a one wire plug.. Nothing missing. Runs your temp gauge.
1995 V6 Mustang= Divorced Duals, Flowmaster 2 chambers, NO CATS, Raxiom Halo Projector headlights, Smoked Tails, 17 inch Bullitt Wheels
1997 Mustang GT: 4.6L DOHC http://www.mustangevolution.com/forum/f280/t305270/
1986 Mustang GT= Built 302 SOLD
95v686gt is offline   Reply With Quote
Old 12-06-2012, 01:19 PM   #5
1slosix's Avatar
it's possible that it truely is a one wire plug...however the previous owner may have had a faulty harness so he rigged a harness from another car onto his. pull the harness off and look at the sensor...if it's a one pin then you're golden
carving corners like a boss
« Hood pins | A/C »
04:05 AM
