Cutting springs - Mustang Evolution
Old 12-08-2012, 12:15 AM   #1
Xaperez100's Avatar
Cutting springs
Would it be bad to cut my v6's springs to make the car lower? And how much could I go?
Xaperez100 is offline   Reply With Quote
Old 12-08-2012, 12:19 AM   #2
FordAddict's Avatar
Cutting creates a looser and floatier ride but will lower the car. I cant remember specs on how to cut but if you search the forum there is plenty on this subject.
FordAddict is offline   Reply With Quote
Old 12-08-2012, 12:21 AM   #3
Xaperez100's Avatar
Alright thanks!
Old 12-08-2012, 12:29 AM   #4
FordAddict's Avatar
How far do you want to lower it? I know alot of knowledge on the subject but just cant remember coil cuts because I used eibach sportlines from a show cobra. If you have any questions on what you may need or if you need help just post back here or feel free to pm me.
Old 12-08-2012, 12:37 AM   #5
1slosix's Avatar
i love cutting the stock springs..great weight transfer and always a good stance
my personal favorite cut is 1.25 coils off the front and 1 coil off the back...it's about a 1" -1.25" drop overall...pull the Isolators to get another 1/4" drop if you want. use a angle grinder with either a metal or bi-metal cutting wheel btw for best cut results...never use a torch or heat the springs
carving corners like a boss
Old 12-08-2012, 12:42 AM   #6
FordAddict's Avatar
I know that the isolators are used to prevent the metal to metal contact, so do you replace them with anything? Wrap the ends of the coils in duct tape or something lol?
What if I cut them in my caddy cts? Haha
Old 12-08-2012, 12:47 AM   #7
1slosix's Avatar
i just put them in with no wrap...i have used electrical tape in the past to give some kind of barrier but honestly they don't make any real noise metal on metal. only when going over a speed bump you'll sometimes hear it shift lol.
and i have no clue..i'd hit up a caddy forum for that
Old 12-08-2012, 12:47 AM   #8
1slosix's Avatar
Old 12-08-2012, 12:55 AM   #9
Xaperez100's Avatar
Thanks man I will! I'm just looking for something that won't really cost me much to do..
---------- Post added at 01:55 AM ---------- Previous post was at 01:54 AM ----------
Thanks ill probably do that!
Old 12-08-2012, 12:59 AM   #10
FordAddict's Avatar
Have you been on a caddy forum? Its a bunch of rich kids who can toss around a couple grand like nothing. They had a group buy on forgestar f14 wheels that they needed like 20 for and they got like 60! Each set was $1800. As for springs, they swear coilovers are the only way to go other than hotchkis springs. Coilovers are $1200-2000 lol...
Old 12-08-2012, 12:59 AM   #11
1slosix's Avatar
np...about 2 weeks after you cut them make sure to have it aligned...i say 2 weeks because your springs will shift and settle..and getting it aligned right off the bat will be pointless...your tires will not be destroyed in that time period for being just under a 1.5" drop.
Old 12-08-2012, 01:03 AM   #12
Xaperez100's Avatar
Oh okay so I'd have to have about $80 set aside for the alignment before I even think about cutting them.. Anyone know who does alignments cheap?
Old 12-08-2012, 01:05 AM   #13
1slosix's Avatar
i'd say more like $50 for a two wheel alignment...$80 is average for a 4 wheel one...and if a shop tries to tell you that you need a 4 wheel alignment go elsewhere lol
Old 12-08-2012, 01:10 AM   #14
FordAddict's Avatar
I know that at the discount tire that I work at that we have shop coupons for a $35 4 wheel alignment. Call up your local dt or similar shops like ntb or just brakes or even google for coupons. No shame in saving money
Old 12-08-2012, 05:02 AM   #15
NooWayyJosayy's Avatar
do you have a picture of the springs after youve cut them? im planning on cutting my springs soon and i wanna know the right angle to cut them at and how they should end up
NooWayyJosayy is offline   Reply With Quote
Old 12-08-2012, 12:18 PM   #16
1slosix's Avatar
i cut straight down into the spring....sadly no pics of when cutting (i've always had more on my mind sadly lol)...however David on here just cut his using the same method and did take a pic
Old 12-08-2012, 12:48 PM   #17
lol alright
Old 12-09-2012, 12:43 AM   #18
davidcseifert's Avatar
Region: Arkansas
You'll have to ignore the rear height because my car is gutted so it didn't drop much beck there lol
Front dropped nice though, handles a lot better it seems but I did new shocks/struts and LCA's in the rear, I can do about 90 around a turn I barely mangled 80 on before
blower/new cam soon
11:16 AM
