Exhaust pipes? - Mustang Evolution
Old 12-11-2012, 08:21 AM   #1
Berry_Eggo's Avatar
Exhaust pipes?
What brand would be good and cheap for an Exhaust?
Berry_Eggo is offline   Reply With Quote
Old 12-11-2012, 09:18 AM   #2
Project Pony's Avatar
Good, and cheap generally don't belong in the same sentance. However a quality setup can be had for a decent price. Let's start with what you are wanting to do? Are you doing a dual conversion, or just replacing the stock single setup?
[SIGPIC][/SIGPIC]
Old 12-11-2012, 09:56 AM   #3
1slosix's Avatar
Thrush Welded is a great brand for cheap. it's a two chamber design which in all honesty sounds like a flow 40. you can buy two for the price of one 40 series in fact at most any auto parts store
To save on cost you can find some used GT tailpipes from either a salvage yard or craigslist (alot of guys have luck with CL for this since GT owners love to upgrade too)
Midpipe choices are up to you. now you can keep the stock y pipe, but back to being honest it just doesn't sound good. So at the minimum most will say get a divorced setup (which means one pipe for each manifold side). other midpipes include h, x, and prochamber...check out youtube for vids and see what sounds good for you
carving corners like a boss
Old 12-11-2012, 10:24 AM   #4
Berry_Eggo's Avatar
Dual conversion
Old 12-11-2012, 10:32 AM   #5
1slosix's Avatar
that's simple then
start with calling all your local shops and getting quotes
Old 12-11-2012, 10:36 AM   #6
Venomouz831's Avatar
Should run you 4-500 bucks with a midpipe
)02 Gt, Founder of WE2G
Old 12-11-2012, 10:46 AM   #7
1slosix's Avatar
come to TN...you can build a full exhaust for around $300
Old 12-11-2012, 10:46 AM   #8
That's dirt cheap
Old 12-11-2012, 10:57 AM   #9
Berry_Eggo's Avatar
What part of TN? I was actually going to go this Saturday
Old 12-11-2012, 11:00 AM   #10
1slosix's Avatar
Northern Middle TN...my last setup the shop charged me $50 a tailpipe..then $50 in labor...the mufflers i brought myself ($39 thrush welded series), and the midpipe i had too which i bought used on CL....i've now used this shop on my last 9 exhausts lol
then again the most expensive shop i've found wanted around $400 here...i think location makes a difference when it comes to exhausts
Old 12-11-2012, 11:11 AM   #11
Berry_Eggo's Avatar
Maybe, i guess ill do some research and see if i can find a cheap location in GA, so tgen i wont
---------- Post added at 11:11 AM ---------- Previous post was at 11:11 AM ----------
Maybe, i guess ill do some research and see if i can find a cheap location in GA, so then i won't have to travel so far
exhaust
06:00 PM
